Author Topic: GP62 MVR 7RFX Lepoard Pro  (Read 180 times)
w4r3zgodTopic starter
« on: 01-September-19, 15:29:47 »
Just made a 'unlocked' bios for the GP62 MVR 7RFX Lepoard Pro, MS-16JB Mobo.
Flash with FPTW64.exe ("FPTW64.exe -F modded.rom -BIOS")
Has all options unlocked.
 * I'm not responsible for bricked devices, thermonuclear war, or you getting fired because the alarm failed.
 * YOU are choosing to make these modifications, and if you point the finger at me for messing up your device, I will laugh at you.
 * Your warranty will be void if you tamper with any part of your device / software.
DL Link: https://anonfile.com/r9NcD344n9/Unlocked_MS-16JB_BIOS_zip
I could not work out how to use attatchments so, I used anon file.
