Author Topic: Notification for the prize winner - ShoutOUt  (Read 510 times)
ivanoraraTopic starter
  • PRIVATE E-1
« on: 04-September-19, 14:58:43 »
Greetings!
I received an email regarding the prize for 'Shout Out for MSI'. It says 'MSI will send the physical prize within 30 working days after confirmation'. The problem is, I am unable to confirm through the email as it is a no-reply email address. I tried the support page but there's no category for this kind of inquiry. Is there any other way I could send my confirmation for the prize?
Let me know please. Thank you!
  • 微星科技
Re: Notification for the prize winner - ShoutOUt
« Reply #1 on: 04-September-19, 15:10:57 »
Contact MSI directly: >>How to contact MSI.<<
AMD Ryzen 9 3900X
Windows 10 Pro
  • PRIVATE E-1
« Reply #2 on: 09-September-19, 12:47:05 »
Err. I'm confused.
I mentioned in my post that I already tried the support but there's no category for my query.
  • 微星科技
« Reply #3 on: 09-September-19, 12:53:35 »
No, there isn't as no one can help you here.
AMD Ryzen 9 3900X
Windows 10 Pro
Chike
  • GENERAL
« Reply #4 on: 09-September-19, 15:46:51 »
Let me understand, MSI sent you an email you need to confirm without any link or instruction  to do it and from a don't reply to account?
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
  • PRIVATE E-1
« Reply #5 on: 10-September-19, 12:17:32 »
Then you should've told that in your initial reply instead of pointing me to the Support page that I already mentioned. Thanks though!
  • PRIVATE E-1
« Reply #6 on: 10-September-19, 12:21:50 »
Yes. That's correct. It's a no-reply email address.  I tried to search the forum but the moderator guy wasn't really helpful from his replies. I'm just hoping that someone here has the same experienced and could share what actioned they did.
Chike
  • GENERAL
« Reply #7 on: 10-September-19, 12:24:51 »
Forum moderators are not MSI reps, the can't help with such matters.
CPU: i5-4670k
