Author Topic: Bios request 2080ti gaming x trio  (Read 2024 times)
mlangdon89Topic starter
« on: 06-September-19, 14:04:45 »
I've seen several posts stating there may be a new version and that it may effect afterburner. I just want to be sure I'd be updating correctly (I've never updated vbios before) and it seems this process requires submitting a post of my own instead of a mass thread.
Bios file from GPU-Z says it's too large to attach, please advise if required.
SN: 602-V371-11SB1810000681
GPU-Z states vbios name as msinv371mh.101
Thank you.
Marked as best answer by mlangdon89 on 07-September-19, 06:35:57
  • 微星科技
Re: Bios request 2080ti gaming x trio
« Reply #1 on: 06-September-19, 14:39:40 »
You are using vbios version NV371MH.101. Latest is NV371MH.105 (attached).
For flashing use nvflash: https://www.techpowerup.com/download/nvidia-nvflash/
note that you need to rename the unpacked file NV371MH.105 to .rom (e.g. 105.rom) for flashing.
If you saved the nvflash for windows .exe say under drive d: you can start it in a Windows prompt in administrator mode after you saved the .rom at the same place. First type d: (or wherever you saved nvflash and the .rom) and press enter. Now you changed to drive d: where you have nvflash in the root directory. Now start the flash with the following line: nvflash -6 105.rom (press enter)
Note that if using a 64bit OS you'll need to run the line nvflash64 -6 105.rom
AMD Ryzen 9 3900X
Windows 10 Pro
« Reply #2 on: 06-September-19, 15:16:09 »
Thanks for the quick reply and the explanation of how to take care of the update.
  • 微星科技
« Reply #3 on: 06-September-19, 15:18:30 »
:hat tip:
AMD Ryzen 9 3900X
Windows 10 Pro
embedonix
  • CORPORAL
    • EMBEDONIX
« Reply #4 on: 16-September-19, 07:04:18 »
Sorry to jump in...I have the same card but at the moment on 104 bios. Is there any good reason to update to 105?
MSI Z390 Gaming Pro Carbon
Intel Core i9-9900k
MSI GeForce RTX 2080 Ti Gaming X Trio
TT Water 3.0 360 ARGB
SHARKOON CA200M
Corsair RM750
HyperX 2x8GB 3600 RGB
Creative SoundBlaster X
WD SN750 500GB/Samsung Evo Plus 860 1TB and some more disks :)
Windows 10 Pro x64
  • 微星科技
« Reply #5 on: 16-September-19, 14:49:04 »
Please open your own thread.
AMD Ryzen 9 3900X
Windows 10 Pro
Kien
  • CORPORAL
« Reply #6 on: 17-September-19, 03:08:33 »
OP how do you check your vbios in gpuz ?
  • 微星科技
« Reply #7 on: 17-September-19, 12:48:04 »
Quite good to further ask something unrelated in a thread after another user has already been told to open an own thread.
>>Please read and comply with the Forum Rules.<<
>>GOP / UEFI Vbios requests - Read Here First<<
:floblock:
AMD Ryzen 9 3900X
Windows 10 Pro
