Author Topic: Is MSI PS42 8RC does have an empty slot for extra SSD  (Read 774 times)
brahmajivvTopic starter
« on: 10-September-19, 11:22:40 »
I wonder is there additional empty slot inside the MSI PS42 8RC model for upgrading the memory or i have to throw away the old SSD inorder to upgrade memory of it.
Marked as best answer by brahmajivv on 20-September-19, 19:43:09
tonda.truong
Re: Is MSI PS42 8RC does have an empty slot for extra SSD
« Reply #1 on: 13-September-19, 08:24:36 »
I have seen the motherboard and there is only one slot for SSD M2. Remeber to buy the right type. If you want to transfer your data to new one, clone it to the new SSD than replace it in your laptop. Abeter booting to windows use disk manager to grow the partition.
« Reply #2 on: 15-September-19, 07:49:53 »
Many thanks for the info. Seems i had to shell out extra for the dock to connect M2 SSD.
tonda.truong
« Reply #3 on: 15-September-19, 10:14:19 »
If you are looking for cheapest way to clone your current disk to a new m2 ssd get a "M.2 sata ssd to usb external ssd reader".
« Reply #4 on: 20-September-19, 10:45:46 »
how cheap option and less speed we choose, still we have to shell out 15dollars, unless using continously as ext HDD.
Many Thanks
