Author Topic: H310M PRO-M2  (Read 393 times)
angelodiegoTopic starter
H310M PRO-M2
« on: 10-September-19, 18:20:40 »
My motherboard H310M PRO-M2 beeps three times on power on and after that starts fine. Neither all times it happens. What must be the problem? Running on W10 LTSB, 8GB RAM 2400, SSD M.2, G5400, plus two HD, 500GB and 1TB. Graphics MSI GTX 1050 TI.
  • T9246ED
  • Administrator
Re: H310M PRO-M2
« Reply #1 on: 10-September-19, 19:48:41 »
what does EZ Debug shows?
does everything works correctly?
Re: H310M PRO-M2
« Reply #2 on: 15-September-19, 11:55:48 »
It begins in sequence turning on and off first the CPU LED, after the DRAM LED, and on the VGA LED it stays on for a while and the buzzer beeping for three times, after that the VGA LED and the buzzer turns off and the BOOT LED turns on and off. After this sequence the mobo starts normal. No loss of performance on Graphics or other device.
  • T9246ED
  • Administrator
Re: H310M PRO-M2
« Reply #3 on: 15-September-19, 22:03:29 »
do >>Clear CMOS Guide<< with power cord removed
then see if this beep will continue.
which model exactly is your video card?
the beeps:
for some msi board they beep at boot depends of numbers of USB key connected [one per each USB device]
other:
did you connected CPU FAN to CPU FAN (not system FAN) on the mainboard header?
Re: H310M PRO-M2
« Reply #4 on: 19-September-19, 16:44:19 »
Thanks for your support. I suspected that the problem began after the bios update to version 7B28vA7. Now i did a new update to version 7B28vA8 and seems tha the problem has been fixed. If it get back i'll try your advices.
  • T9246ED
  • Administrator
Re: H310M PRO-M2
« Reply #5 on: 22-September-19, 08:58:48 »
got it, thanks for update
