Author Topic: Request for vBIOS RX580 X 8G Gaming  (Read 274 times)
amoruso.hussainTopic starter
« on: 13-September-19, 05:50:45 »
HI,
Just brought a pair of RX580 from eBay but I suspect they have the wrong flash on it as they are freezing during gaming session every few days.
Someone suggested that I get a new flash for them.
The serial numbers are with specs.
Radeon RX580 Gaming X 8G
602-V341-350B1710004285
602-V341-350B1710004297
Thanks
  • 微星科技
Re: Request for vBIOS RX580 X 8G Gaming
« Reply #1 on: 13-September-19, 10:11:05 »
The latest correct vbios for both cards is TV341MH.614: https://forum-en.msi.com/index.php?topic=301097.msg1749605#msg1749605
AMD Ryzen 9 3900X
Windows 10 Pro
« Reply #2 on: 16-September-19, 06:27:51 »
Cards Flashed :D
Thanks for the support. if you hear nothing it means its worked great :D and many thanks
  • 微星科技
« Reply #3 on: 16-September-19, 14:51:22 »
:hat tip:
AMD Ryzen 9 3900X
Windows 10 Pro
