Author Topic: MSI X58 PLATINUM SLI X5680  (Read 190 times)
frodowin1Topic starter
« on: 16-September-19, 02:50:52 »
im new to overclocking  id like to get close to 3.8 or 3.9 i have pics of my info any help would be appreciated
Voltage
 +3.3V 3.296 V
 CPU CORE 0.968 V
 +5V 4.919 V
 +12V 12.144 V
 VSB3V 3.360 V
 CMOS BATTERY 3.312 V
6 cores Threads 12
Name Intel Xeon X5680
Code Name Westmere-EP
Package Socket 1366 LGA
Technology 32nm
Specification Intel Xeon CPU X5680 @ 3.33GHz
DDR 3   Size 4096 MBytes
Manufacturer G.Skill
Max Bandwidth PC3-12800 (800 MHz)
Part Number F3-12800CL9-4GBRL
SPD Ext. XMP                   24 gigs total
Chike
  • GENERAL
Re: MSI X58 PLATINUM SLI X5680
« Reply #1 on: 16-September-19, 07:41:07 »
This is ancient technology.
One mistake he make there is enabling spread spectrum, it should be disabled for more stable overclock, but may be left auto as well.
Use HWiNFO to record default values and monitor while overclocking, it has much more outputs than cpu-z and realtemp.
Not sure about safe voltages you will have to search that too.
Also he says multiplier is locked on 22 but this cpu turbo boost is up to 25.
Your cpu multiplier is 25 and turbo boost 27 so it may be possible to achieve higher clocks with lower bclk with turbo boost enabled and cpu ratio on auto.
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
