Author Topic: RX470 GAMING 4G BIOS  (Read 525 times)
i6emsnTopic starter
« on: 16-September-19, 15:17:33 »
Hi!
I got a RX470 GAMING 4G (NON X) VGA that has a modded bios therefor i can not install latest driver properly.
Could you send me the latest official bios for my graphics card?
The serial number is:
602-V341-67SB1701000024
Thank You!
i6emsnTopic starter
Re: RX470 GAMING 4G BIOS
« Reply #1 on: 16-September-19, 15:21:22 »
Actual modded bios is: TV341MH.2J2
  • 微星科技
« Reply #2 on: 16-September-19, 15:27:09 »
The latest original vbios is TV341MH.2J4. It is attached.
For flashing ATIWinflash in Windows. Should explain itself.
Note that you need to rename the vbios file to .rom for flashing after unpacking.
AMD Ryzen 9 3900X
Windows 10 Pro
i6emsnTopic starter
« Reply #3 on: 16-September-19, 17:06:58 »
I can not see the attached file :embarassed:
Where shall i find it?
  • T9246ED
  • Administrator
« Reply #4 on: 17-September-19, 07:18:44 »
here it is
i6emsnTopic starter
« Reply #5 on: 17-September-19, 08:53:13 »
Thank You two, guys :)
i6emsnTopic starter
« Reply #6 on: 17-September-19, 09:41:40 »
Yupppieee, it works great :pompom:
I have another VGA on the shelf, lets try to fix that one as well :agrees:
RX470 Gaming X 4G
602-V341-020B1611000103
Could it be the same BIOS?
  • 微星科技
« Reply #7 on: 17-September-19, 12:56:01 »
:bonk: sorry! I forgot to attach it
AMD Ryzen 9 3900X
Windows 10 Pro
i6emsnTopic starter
« Reply #8 on: 17-September-19, 12:59:47 »
No probs, mate, your "colleauge" helped me out 8-))
Can You tell me if this card use the same bios or not:
RX470 Gaming X 4G
If not, could You attach a proper BIOS?
  • 微星科技
« Reply #9 on: 17-September-19, 13:19:41 »
The card is from a different batch than the other. The latest vbios for it is TV341MH.216. Get it here: https://forum-en.msi.com/index.php?topic=298249.msg1680360#msg1680360
AMD Ryzen 9 3900X
Windows 10 Pro
