Author Topic: do i need to update my MSI RTX 2080 TI GAMING X TRIO bios ?  (Read 923 times)
KienTopic starter
  • CORPORAL
i have never looked up what is my gpu bios version or even update it since i bought it until now . i saw alot of people out there looking for new bios .
do i need to keep my gpu bios updated ? i dont know anything about this .  let me know if i need to update to a newer version of bios . much appreciated !
d
My current bios version info from :
GPU-Z : 90.02.17.00.2C
Windows adapter properties : driver date : 9/5/2019
                                                driver version : 26.21.14.3630
GPU S/N : 602-V371-11SB1811001744
plutomate
  • MAJOR GENERAL
Re: do i need to update my MSI RTX 2080 TI GAMING X TRIO bios ?
« Reply #1 on: 17-September-19, 03:12:25 »
you never "need" to update BIOS unless there's any problem with your card.
however, you could request the latest vBIOS and flash it but it's pretty pointless to do so.
KienTopic starter
  • CORPORAL
« Reply #2 on: 17-September-19, 04:06:14 »
ohhh i see but keeping your hardware driver up to date is a good thing right ?
  • 微星科技
« Reply #3 on: 17-September-19, 12:51:58 »
If you want to have the latest vbios we need to know what you have now. The numbers you listed for version are useless.
Follow >>GOP / UEFI Vbios requests - Read Here First<< on how to check.
Updating driver is a good thing in any case. You can check for the latest here: https://www.geforce.com/drivers
AMD Ryzen 9 3900X
Windows 10 Pro
KienTopic starter
  • CORPORAL
« Reply #4 on: 17-September-19, 21:51:49 »
current vbios : MSINV371MH.103
S/N: 602-V371-11SB1811001744
ps: this is my first ever time attemping to update gpu vbios any guide to how to update ?
Chike
  • GENERAL
« Reply #5 on: 17-September-19, 22:28:55 »
If everything is working as it should, no crashes, performance as expected, why update anything?
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
KienTopic starter
  • CORPORAL
« Reply #6 on: 17-September-19, 22:36:34 »
hey thanks for the reply . yes i have experience random unexpected crashes in games like fortnite and rainbow 6 siege not very often but when it happens the only way to resolve this is to restart my pc i cant open up task manager to kill the task because i cannot open anything when the game goes full black . i have tried everything such as fresh reinstall windows and fresh reinstall nvidia driver and updating my mobo bios etc but nothing works . so there is one of the guy from Linus tech tip forum ask me look into my gpu vbios . before that i didnt even know a gpu bios exist .
Chike
  • GENERAL
« Reply #7 on: 17-September-19, 22:49:43 »
This something that needs to be resolved, but it may be game specific thing, have you tried to search similar crashes for other users?
CPU: i5-4670k
KienTopic starter
  • CORPORAL
« Reply #8 on: 17-September-19, 23:11:58 »
im pretty sure not the game it self , csgo and bf5 giving me the same problem as well. it does not happen often like i said but when it happen is a mess .
the info i have gather/research online is very less because nearly 1% of the people have this kind of problem (base on my research)
and they didnt have solution to resolve their issue as well .
i have tested my pc such as cpu,ram etc is in a very good condition .
the video blacks out when the crash happen . i can tell i can open up anything in the background but i coudnlt control them because when i press ALT+TAB it will remain at the game with full black screen so i just press start button and restart the pc everytime when crash happen .
so this tells me highly likely is from the gpu it self
Chike
  • GENERAL
« Reply #9 on: 17-September-19, 23:16:17 »
Try to look in event viewer if there is more detail on what happens.
CPU: i5-4670k
KienTopic starter
  • CORPORAL
« Reply #10 on: 17-September-19, 23:21:19 »
im sorry but where is event viewer ? also forgot to mention that this happen since the first day i got this gpu . i just didnt thought i should be worrying but until my friend says why you have this kind of problem with your pc . we all doesnt have then i start looking into the issue
Chike
  • GENERAL
« Reply #11 on: 17-September-19, 23:33:46 »
If you are using windows 10, right click the start button, you will see it near the top.
If you are using windows 7, click start and type event, you should find it on the list.
Did you have another gpu it did not happen with before?
CPU: i5-4670k
KienTopic starter
  • CORPORAL
« Reply #12 on: 17-September-19, 23:44:52 »
yes i have another rtx 2080ti from asus strix in my another rig i have tried using that to my bedroom rig which is this one for a week . but nothing happen and surprisingly asus strix card have good cooling .
but no , no crash happen it run fine !
 i have done alot of research recently to find any solution for my gpu but i didnt found any and try everything i could like ( fresh reinstalling windows , nvidia driver , testing ram , cpu etc ) even go as far as swapping psu.
things still happen until i post my issue to LTT forum and telling them what i have do/tested to make sure everything is ok beside gpu . then they tell me to look into msi forum and try to see if any solution for this vbios update/etc
  • 微星科技
« Reply #13 on: 18-September-19, 13:07:30 »
current vbios : MSINV371MH.103 S/N: 602-V371-11SB1811001744 ps: this is my first ever time attemping to update gpu vbios any guide to how to update ?
There is an update. Latest is NV371MH.105 (with instructions): https://forum-en.msi.com/index.php?topic=324660.msg1845355#msg1845355
AMD Ryzen 9 3900X
Windows 10 Pro
Chike
  • GENERAL
« Reply #14 on: 18-September-19, 23:57:09 »
To rename a file in windows, right click the file in file explorer (windows explorer in windows 7) and select rename.
Or you can do it in command prompt, type: ren NV371MH.105 105.rom <enter>
I guess it is because nvfash require that the file has extention ".rom"
CPU: i5-4670k
KienTopic starter
  • CORPORAL
« Reply #15 on: 19-September-19, 00:03:25 »
hey thanks for the reply . i think i just sucessfully flash the bios . can you help me take a look if i did i correctly ? thank u
edit: sorry for the blur picture
Chike
  • GENERAL
« Reply #16 on: 19-September-19, 00:49:02 »
If it says update successful then it is :biggthumbsup:
CPU: i5-4670k
  • 微星科技
« Reply #17 on: 19-September-19, 14:12:50 »
You can see that it is at .105 in the gpu-z report that you added as a screenshot.
AMD Ryzen 9 3900X
Windows 10 Pro
