Author Topic: New Dragon Center with RTX 2070 Super Error when PC is restarted  (Read 226 times)
christizzzTopic starter
i installed an RTX 2070 Super Gaming X trio. I then installed the new Dragon Center.
It is working ( there is a lot of bloatware though).... i noticed under the Reliability History of windows that each time i restart the PC, 2 MSI services are crashing.  LEDkeeper and the dragon service.
To replicate this you need to RESTART the PC and not shut it down.. then go into Rerliability history of Windows and the errors should be there.
Shuting down the PC does not generate an error.
  • T9246ED
  • Administrator
which version you use?
and do you mean the older version works fine without issue?
have you tried to reinstall it?
which mainboard you use too?
provide a detailed system specs:
>>Posting Guide<<
