Author Topic: MSI MORTAR MAX + Game Boost + XMP  (Read 599 times)
FrizzerTopic starter
« on: 06-October-19, 10:06:49 »
I bought this week a AMD Ryzen 5 3600, a MSI MORTAR MAX and 16g RAM Gskiil 3200 Cl16
After everything setup with the latest bios, I activated the xmp to achieve the ram frequency. Everything ok. I tried to turn on the Game Boost and Windows crashed (bsod). Is it poosible to have the xmp and Game Boost running togheter?
Nichrome
Re: MSI MORTAR MAX + Game Boost + XMP
« Reply #1 on: 06-October-19, 15:29:30 »
Hi
I might be wrong, but doesn't Game Boost enable XMP itself? Never used it to be honest, always OCed my components manually.
When you enable Gameboost with XMP off, does it also crash?
« Reply #2 on: 06-October-19, 19:25:46 »
Only crash when both are enabled. With Game Boost enabled the ddr freq is not the correct for my ddr.
Chike
  • GENERAL
  • Online Online
« Reply #3 on: 06-October-19, 20:00:16 »
What bsod code is it?
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
« Reply #4 on: 07-October-19, 05:56:15 »
I can't tell you. The error screen is oversized and the code is not visible.
Chike
  • GENERAL
  • Online Online
« Reply #5 on: 07-October-19, 06:05:48 »
You can find it in event viewer.
CPU: i5-4670k
« Reply #6 on: 08-October-19, 14:30:44 »
I did it today again and again Windows crashed with bsod. In the event viewer are many events and I don't know which is the one.
If anyone can help!
montyac
  • MAJOR
« Reply #7 on: 08-October-19, 14:40:03 »
Try contacting MSI support regarding the crashing issue. For now, just disable Game Boost and run your ram with an XMP profile.
Chike
  • GENERAL
  • Online Online
« Reply #8 on: 08-October-19, 15:46:23 »
BugCheck is the blue screen.
Youre even log is all red, and that's not good sign at all.
CPU: i5-4670k
