Author Topic: Upgrade of Storage to my MSI  (Read 424 times)
NitrozeuSTopic starter
« on: 12-October-19, 05:53:41 »
I am currently using only HDD in my MSI. I plan to extend the storage with already available Samsung EVO 860 msata SSD. But my MSI supports only  NVMe PCIe gen3. Is there any adapter available in market to attach my msata to NVMe port.Or any other option available
l.r.gardner
  • STAFF SERGEANT
Re: Upgrade of Storage to my MSI
« Reply #1 on: 12-October-19, 08:36:04 »
You're in luck because mSATA is SATA, so pci express is going to be irrelevant. Google "msata to sata adapter". It will make it into the same shape as a 2.5in hdd/ssd. :) I've used them personally they work fine.
Ryzen 5 3600@stock
MSI B450-A Pro Bios AC.1
16GB 2x8 Crucial Ballistix Sport LT 3200@1.35-3733
ASUS ROG STRIX-RX480-O8G-GAMING
Intel 660p 1TB NVME
WD Blue WD20EZRZ 2TB
Corsair CX850M PSU
« Reply #2 on: 13-October-19, 00:58:26 »
Using that adapter will make me to remove my HDD.But I need to use both SSD and HDD.
l.r.gardner
  • STAFF SERGEANT
« Reply #3 on: 13-October-19, 08:01:42 »
I assumed you had a desktop because you didn't say you had a laptop! Let me know what laptop model you have. If it supports m.2 sata as well as m.2 nvme you can use an adapter to go from m.2 sata to msata. If your laptop only supports m.2 nvme and NOT m.2 sata, you will have to do what I'm saying and replace your hard drive with it. Hard drives suck anyway, you are better off without it especially in a laptop.
Ryzen 5 3600@stock
Intel 660p 1TB NVME
Corsair CX850M PSU
lamb_donald
« Reply #4 on: 26-October-19, 14:48:12 »
I'm also seeking information re: upgrading my SSD from 128MB to 1 TB.  I'm looking at the Intel 1TB SSDs.  Does anyone know what Intel SSDs are compatible with the GS63VR 6RF Stealth Pro?
Thanks in advance.
Chike
  • LIEUTENANT GENERAL
« Reply #5 on: 26-October-19, 15:40:23 »
What is your msi?
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
lamb_donald
« Reply #6 on: 26-October-19, 17:16:25 »
Chike
« Reply #7 on: 26-October-19, 17:32:57 »
https://www.msi.com/Laptop/GS63VR-6RF-Stealth-pro/specification
This laptop has a 2.5" sata bay, and sata/nvme m.2 slot
CPU: i5-4670k
