Author Topic: Appreciate some OC help - Corsair i160 - 9900k, z370i, mini itx  (Read 210 times)
adam_jordgubbeTopic starter
HI, there
Full specifications.
9900k, liquid cooled
RTX2080TI, liquid cooled
32GB 2666 DDR4
480gb M.2
z370i mini-ITX
SF600, 80 plus Gold
W10
So I have tried different OC settings following a MSI guide on the tube, from gameboost none with and without XMP to manually OC.
The bios are up to date.
2.QJ 05/22/2019
I used only 3dmark to evaluate by score.
These are the OC settings tried so far.
1.
OC Explore Mode [Expert]
CPU Ratio Apply Mode [All Core]
CPU Ratio 50
CPU Ratio Mode [Fixed Mode] All Run at 5Ghz no matter what for system stability
CPU Ratio Offset When Running AVX [-3] (This was a tip from the online guide)
2.
DigitALL Power>
CPU Loadline Calibration Control [Mode 4]
3.
CPU Core Voltage 1.320
CPU SA Voltage 1.200
CPU IO Voltage 1.200
DRAM Voltage 1.360
4.
Overclocking\CPU Features
Intel C-State [Disable] (Power saving mode)
CPU Ring Ratio 47 3 under
CPU Core Voltage Mode "override > auto (thesame?)
Haven't put out a throttling power limit it is on auto. Should I?
Results:
These are done with the GPU unchecked with the demo unchecked aswell, custom run, just CPU test in TimeSpy 3dmark.
1. STOCK
CPU-Z / 3DMark CPU test score 9 057 (3.6Ghz) 9169 XMP enable
2. Game Boost
CPU-Z / 3DMark CPU test score 10 426 (4.8Ghz / 4000GHZ in the end) 10 242 XMP enable
3. Enhanced Turbo + XMP (CPU-Z BENCH @5GHZ 582.3 5050.1)
CPU-Z / 3DMark CPU test score 10 575 (5GHZ, dropped to 4.4GHZ in the end)
4. 5Ghz Overclock + XMP (CPU-Z BENCH @5GHZ 587.9 5242.3)
CPU-Z / 3DMark CPU test score 8 784
For manual 4. I got a lower score, this was quite interesting, however the Gameboost options works over 5GHZ, I think around 5.1 but Stock had a higher output.
Temperatures is a bit oddball aswell,
Never really understood the fan curve on this setup.
Temps are at 53-54 however before fans goes up I see Core0 all the way up to 71 and rest jumps a bit setting the overall package up towards 71, it is a bit unsteady and Core0 is a bit higher overall.
CPU jumps from 4700 to 5000.
So what can I do, any suggestions?
  • Online Online
  • 微星科技
Corsair i160 is a Corsair branded PC and no MSI product. This forum just covers MSI retail products.
Go to Corsair forums or check a general computer forum.
:floblock:
Windows 10 Pro
MSI MAG BUNKER Case
