Author Topic: MSI RX5700 MECH OC new BIOS  (Read 402 times)
t.ficsor84Topic starter
« on: 27-October-19, 02:57:04 »
Dear MSI,
I have a problem. The card won't wake up properly from a system sleep state. I have to physically remove the display port cable and plug it back in and it works. Annoying.
I reinstalled the machine, it didn't help.
Driver reinstallation does not help.
Please make a new bios which will fix this problem.
Thanks.
  • 微星科技
Re: MSI RX5700 MECH OC new BIOS
« Reply #1 on: 27-October-19, 04:52:18 »
Dear MSI,
You are not contacting MSI here. To do so: >>How to contact MSI.<<
What do you mean by sleep state? You mean when the entire system is at sleep? If so the rest works?
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #2 on: 27-October-19, 08:11:56 »
When I listen to music and the monitor turns off, but the machine goes on.
I move the mouse, but it doesn't wake up.
Only if I disconnect and plug in the HDMI cable.
  • 微星科技
« Reply #3 on: 27-October-19, 09:40:55 »
So you don't mean sleep but when the pc is idle and monitor is turned off.
Add full system specs: >>Posting Guide<<
Did it work with a different graphics card?
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #4 on: 27-October-19, 11:23:23 »
There was no problem with any other video card, only this one.
More people have reported this error.
  • 微星科技
« Reply #5 on: 27-October-19, 14:19:10 »
What other card? Still add system specs: >>Posting Guide<<
Who did report what?
Windows 10 Pro
MSI MAG BUNKER Case
heymel10O
  • SERGEANT
« Reply #6 on: 28-October-19, 23:39:45 »
Did you try another monitor?
theetechy
« Reply #7 on: 02-December-19, 01:35:48 »
There are many instances and reports of MSI RX5700 XT MECH OC card getting overheated in this forum and simple search using bing/google/baidu will lead to all the issues reported.
I'm baffled by the moderator's lethargic response and mistreatment of customer who already brought the card. (This is NOT a free forum, MSI /moderator has liability to support customer questions)
As a customer who want to buy this specific card for my build, I cannot find answers from MSI/ moderators for the below topics.
why this card overheats under gaming load ?
Will there be bios update to fix the heating issues ?
Is the VRAM, Memory properly cooled under load?
Was it cooling performance tested properly before releasing to market ?
If I wont find answers in 2~3 days Im happy to buy from other board partners
  • 微星科技
« Reply #8 on: 02-December-19, 14:33:18 »
This is a user to user forum. If you want to contact MSI: >>How to contact MSI.<<
Also don't resurrect old topics.
:floblock:
Windows 10 Pro
MSI MAG BUNKER Case
