Author Topic: MSI GAMING APP does not detect my GPU  (Read 179 times)
cuetoon00Topic starter
  • SERGEANT
« on: 29-November-19, 04:40:33 »
MSI Gaming app does not detect my RX 470 armor OC.
System specs:
B450m Mortar max
R5 1600
16gb ram dual channel mode
Rx 470 armor OC 4gb
I have already updated my bios and installed the latest version of Gaming App. I have also tried to install an older version that I found here in the forums but it did not want to launch.
Also, functions only shows Eyerest
Thanks
Marked as best answer by cuetoon00 on 11-December-19, 08:18:56
  • 微星科技
Re: MSI GAMING APP does not detect my GPU
« Reply #1 on: 29-November-19, 12:56:10 »
Yes, that is normal as your card does not support Gaming APP. You don't have a Gaming series graphics card with features to be supported by the APP.
Windows 10 Pro
MSI MAG BUNKER Case
  • SERGEANT
« Reply #2 on: 01-December-19, 00:41:17 »
Hey, Thanks very much for the information. I see why now. Thanks.
  • 微星科技
« Reply #3 on: 02-December-19, 14:08:45 »
:hat tip:
Windows 10 Pro
MSI MAG BUNKER Case
