Author Topic: RTX 2070 super ventus or armor?  (Read 175 times)
chipster339Topic starter
« on: 29-November-19, 15:51:46 »
I am undecided. Can you please tell me which one performs better, which one is cooler and which one is less noisier?
  • 微星科技
Re: RTX 2070 super ventus or armor?
« Reply #1 on: 29-November-19, 16:21:15 »
The performance will be pretty much the same. Might be that the Armor sometimes boosts longer because of the better cooling. The Armor is more silent and features Zero Frozr (stopping fans at temps below 60°C). The Ventus uses a more simple cooling solution with fans always spinning.
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #2 on: 29-November-19, 17:09:47 »
Will gygabyte be better? Since it has 3 fans? At this point i have no idea what nvidia card will give me the lowest temperature possible when gaming with the highest performance. rtx 2070.
  • 微星科技
« Reply #3 on: 29-November-19, 17:47:31 »
Em, this is an MSI brand forum...
If you want best temps and three fans go for MSI GeForce RTX 2070 SUPER GAMING Z TRIO
Windows 10 Pro
MSI MAG BUNKER Case
