Author Topic: Afterburner Opening and closing  (Read 113 times)
infam0usd33dTopic starter
« on: 01-December-19, 02:26:42 »
Hi!
I seem to have a weird problem with afterburner running in the background.  And I haven't been able to find anything to help me.  So, the issue is it will close and re-open about 256 times.  Probably more, math is too much late at night.   I don't see a normal pattern to it doing this.  It's not specific to anything I'm doing at the time, or any setting in the program that I have found.  It'll do it when I have it open also.  Also, after a while, it'll just stay closed.  Won't re-open it self.
System is:
MSI MPG Z390 Gaming Pro Carbon AC
MSI GeForce 1660 Ti
Intel Core i5-9600K
Corsair Vengence DDR4 3200MHz 32GB
2x Samsung 1TB Evo Pro (Raid 0)
Any one?  Any body?  Okay
Thanks
  • 微星科技
Re: Afterburner Opening and closing
« Reply #1 on: 02-December-19, 14:09:45 »
That sounds quite weird. Do you have other software issues with your pc?
Windows 10 Pro
MSI MAG BUNKER Case
