Author Topic: Need stock bios for RX 570 Armor 4g oc  (Read 140 times)
foxbox9Topic starter
« on: 03-December-19, 11:55:57 »
I recently acquired 2 RX 570 Armor 4g oc gpus. AMD drivers doesn't recognize either of them. Im assuming they were mined with. I tried to flash the only 2 bios that Techpowerup had. I get a mismatch error.
Here is the 2 gps that i need the stock bios for.  s/n 602-v341-690b1711000073      s/n 602-v341-250b1711003582
Thank you for your assistance.
  • 微星科技
Re: Need stock bios for RX 570 Armor 4g oc
« Reply #1 on: 03-December-19, 15:20:23 »
Windows 10 Pro
MSI MAG BUNKER Case
« Reply #2 on: 04-December-19, 15:34:12 »
Both stock vbios worked like a champ. Msi tech, you are awesome. This is why Msi is the best, great tech support.
  • 微星科技
« Reply #3 on: 04-December-19, 16:28:40 »
:hat tip:
Windows 10 Pro
MSI MAG BUNKER Case
