Author Topic: Screen freezes at startup with MSI Logo  (Read 120 times)
southerntechnologiesTopic starter
« on: 12-December-19, 15:15:50 »
Have installed an MSI MPG z390 Gaming Pro Carbon MOBO with Intel I59600k processor. Have a DVD drive, HDD and SSD all reformatted. Video card is MSI GTX 970 Gaming 4G. Other items include an ML240L Masterliquid cooler and Corsair 750W PSU. On power-up if nothing is done, the video screen shows an MSI logo and a spinning dot circle which freezes in a couple seconds. Can reboot and by pressing the DEL key can access the BIOS. Nothing unusual is displayed there. Reconfigured the DVD as the default boot drive and installed a windows 10 OS disk and restarted machine......window emblem appeared and stopped....after a minute or so, a blue screen appeared saying that a machine error prevented window from proceeding......end of story! Can anyone tell me the solution for this problem????
Nichrome
Re: Screen freezes at startup with MSI Logo
« Reply #1 on: 14-December-19, 15:32:33 »
Hi
Try without graphics card installed.
Also what exactly are the drives you are using?
« Reply #2 on: 14-December-19, 16:28:39 »
Can't leave graphics card out....there is no on board vga. I took the mobo out and set it on an isolated pad....connected atx Power and CPU power 1 & 2...power on switch, one DVD drive with win 10.... still freezes....got an RMA and sent it back to MSI....happy holidays!
Nichrome
« Reply #3 on: 15-December-19, 11:30:18 »
:confused2:
https://ark.intel.com/content/www/us/en/ark/products/134896/intel-core-i5-9600k-processor-9m-cache-up-to-4-60-ghz.html
Processor Graphics
Processor Graphics ‡
Intel® UHD Graphics 630
Graphics Base Frequency
350 MHz
Graphics Max Dynamic Frequency
1.15 GHz
Graphics Video Max Memory
64 GB
4K Support
Yes, at 60Hz
Max Resolution (HDMI 1.4)‡
4096x2304@24Hz
Max Resolution (DP)‡
4096x2304@60Hz
Max Resolution (eDP - Integrated Flat Panel)‡
4096x2304@60Hz
DirectX* Support
12
OpenGL* Support
4.5
Intel® Quick Sync Video
Yes
Intel® InTru™ 3D Technology
Yes
Intel® Clear Video HD Technology
Yes
Intel® Clear Video Technology
Yes
# of Displays Supported ‡
Device ID
0x3E98
Did you try without DVD drive connected? I've heard of sometimes issue being between optical drive and SATA controller.
