Author Topic: Dragon Center and Trident Z RGB  (Read 209 times)
razr84Topic starter
« on: 14-December-19, 05:20:18 »
Hey Community,
I was build a new config yesterday and i have a frustrating problem.
The Dragon Center (Mystic Light) does not recognize the memory moduls (G.Skill Trident Z RGB) but as I read this type of memories are compatibles with MSI Mystic Light.
I tried everything what I find at here and other sites but nothing changed.
Any idea?
Thanks for the help!
  • 微星科技
Re: Dragon Center and Trident Z RGB
« Reply #1 on: 14-December-19, 12:39:43 »
What mainboard and what exact RAM do you have? -> >>Posting Guide<<
Also what version of Dragon Center are you using?
Windows 10 Pro
MSI MAG BUNKER Case
razr84Topic starter
« Reply #2 on: 15-December-19, 16:22:16 »
Hey,
Sorry for the few information.
MOBO: MPG Z390M Gaming Edge AC with the last (not BETA) BIOS E7B50IMS. 160
RAM: G.Skill Trident Z RGB
Dragon Center: 1.0.0.63
Mystic Light: 1.0.0.31
This is a new config, before this i have an Asus MOBO, I use Asus Aura but I did not reinstall the OS after MOBO change just uninstall all of Asus programs. Can this be the problem?
  • 微星科技
« Reply #3 on: 16-December-19, 13:07:29 »
If you are using Aura that can indeed be a problem
Windows 10 Pro
MSI MAG BUNKER Case
razr84Topic starter
« Reply #4 on: 16-December-19, 13:20:00 »
The Aura was uninstalled before install the Dragon Center.
Now I am using Dragon Center only!
  • 微星科技
« Reply #5 on: 16-December-19, 14:03:38 »
Did it come with some components still remaining like SDK? Check Apps & Features
Windows 10 Pro
MSI MAG BUNKER Case
razr84Topic starter
« Reply #6 on: 16-December-19, 14:46:46 »
Maybe yes.
I think I need to reinstall a new clean windows, right? And if nothing change I will wright again here.
Is it true? I found it on G.Skill forum:
2. MSI Mystic Light
- Must have Trident Z RGB Control software installed for the "LightingService" to run in the background, but does not need the Trident Z RGB software to be opened. (If Trident Z RGB software is not installed, then Mystic Light would only be able to set lighting effects to one module.)
- MSI X299 motherboards have Trident Z RGB recognition issues. Until this is resolved by MSI, please use the G.SKILL Trident Z RGB lighting control software to control memory RGB lighting.
Thank you.
  • 微星科技
« Reply #7 on: 16-December-19, 15:02:24 »
You can try with the GSkill software first. i guess a fresh install might be the way to go though.
Windows 10 Pro
MSI MAG BUNKER Case
