Author Topic: IRQ sharing???  (Read 2168 times)
vaporbrother
IRQ sharing???
« on: 11-November-03, 05:22:45 »
Hi guys!!!!!  just want to ask about IRQ sharing.... i've noticed that my VGA and USB are sharing the same IRQ. Is that normal?
Thanks Again Much!!!!!! :lol_anim:
Richard
  • nForce & GeForce Guru
« Reply #1 on: 11-November-03, 06:01:21 »
  • Best Answer
  • vaporbrother,
    The Geforce4 Ti Series and the GeforceFX Series do not like to share IRQs Period.
    Try disabling the USB Controller if you start having problems.
    Take Care,
    Richard
    Richard J. Gentil, Pres.
    Custom Computers of Naples, Inc.
    LANPARTY nF4 SLI-DR
    Athlon64 3700+ Sandy
    (o/c'd 2.8Ghz)
    Zalman CNPS9500LED
    2-1Gb Mushkin Extreme PC-4000 (Slots 2 & 4)
    (o/c'd 510Mhz)
    2 x MSI NX6800GT-T2D256 (o/c'd Stock)
    X-Mystique 7.1 GOLD - Dolby Digital Live
    2-WD Raptors Raid 0
    (16k Stripe)
    NEC 16 Dual Layer DVD+/-RW
    Logitech Z-680 500W Dolby Digital DTS THX 5.1
    Logitech MX1000 Laser Mouse
    Saitek Eclipse Keyboard
    vaporbrother
    « Reply #2 on: 11-November-03, 06:03:54 »
    thanks a lot aqain DEATHSTALKER !!!!!!!!!
    But i don't have any problems experiencing right now,  but if i do i will try your advice ..... But is this normal to have one IRQ shared?
    conio
    • FIRST LIEUTENANT
    • Zzzz Zzz Zz
    « Reply #3 on: 11-November-03, 07:36:51 »
  • Best Answer
  • IRQ sharing is a normal process as the system can use the IO port range to identify the actual device that requested the IRQ.
    It is only the IO port and memory range that can`t be shared among devices.
    Usualy IRQ sharing is employed between devices that are conected toghether(video and AGP port) or between devices that are on the same bus(two boards on the PCI bus).
    Having IRQ`s shared does have a degrading effect on performance as the system must query all devices that sare a IRQ in order to determine with one has requested it witch means a lot of overhead compared to a no IRQ sharing scenario.
    As such having a fast video card sharing it`s IRQ will lead to a small performance drop and posibly some stability issues with some hardware drivers.
    System:
    ASUS P5Q
    E6600 Core 2 duo
    6G RAM
    Gigabyte NX88T512HP GF8800GT 512MB
    MSI TV-@nywhere Master
    Seagate Baracuda 120G, 8M cache -> went external
    Seagate ST3250410AS
    Seagate ST31500341AS
    WDC WD2500JS
    WDC WD5000AAKS
    NEC ND-3540A
    Samsung SyncMaster 959NF :like: :like: :like:
    Antec Performance TX1088AMG   :agrees:
    Corsair VX550
    Logitech Z640  :dance:
    OS:WinXP & Windows 7 x64
    vaporbrother
    « Reply #4 on: 11-November-03, 08:20:34 »
    thanks!!!! But how about my IRQ 16 is being shared by VGA and USB? Is that a conflict or affecting the performance of my VGA ? Thus also disabling my USBs will help like Deathstalker is saying?
    conio
    • FIRST LIEUTENANT
    • Zzzz Zzz Zz
    « Reply #5 on: 12-November-03, 07:39:48 »
  • Best Answer
  • As long as you don`t see any exclamation icons on any of the devices there is no conflict but if you do not use the USB you should disable it as it simply eats up resources.
    Also because the USB is a asynchronous device the performance of the video should be only very sligthy affected as the video trafic will take precedence over the USB.
    So the best solution is either to disable the USB or, if and only if you use it,  to see if you can change the IRQ assignment from the computer BIOS.
    System:
    ASUS P5Q
    E6600 Core 2 duo
    6G RAM
    Seagate ST3250410AS
    WDC WD2500JS
    WDC WD5000AAKS
    NEC ND-3540A
    Corsair VX550
    vaporbrother
    « Reply #6 on: 14-November-03, 02:10:32 »
    conio my man thanks a lot!!! but how can i change the IRQs ?
    conio
    • FIRST LIEUTENANT
    • Zzzz Zzz Zz
    « Reply #7 on: 14-November-03, 11:46:40 »
  • Best Answer
  • Usually it be done by changing the position on the PCI bus but because we`re dealing with a built in usb controller and the AGP bus this if not phisically posible. :wall:
    So the only other option is to search in your BIOS for the IRQ allocation table and see if you can do anything from there. :undecided:
    System:
    ASUS P5Q
    E6600 Core 2 duo
    6G RAM
    Seagate ST3250410AS
    WDC WD2500JS
    WDC WD5000AAKS
    NEC ND-3540A
    Corsair VX550
    vaporbrother
    « Reply #8 on: 14-November-03, 19:47:43 »
    thanks a lot Conio!!!!!     as long as i don't have problems i think i'll be fine
    MORE POWER !!!!!! it's FRIDAY ... PARTY TIME!!!!
    Bootstritty
    • FIRST LIEUTENANT
    « Reply #9 on: 15-November-03, 17:14:30 »
  • Best Answer
  • Mine share and I have not had any problems. The games I play (half-life mods, Ghost recon',bf1942 and others)  run without crashing. with the right INF files and the OS getting instuctions from the mother board on how to configer things you should not have any problems most of the time.  KEY WORD MOST . Are you haveing problems? if not enjoy. alot of times the problems come from software conflicts.
    3.2 P4c 800MHz FSB
    Intel D865PERL
    1024 MB of PC3200
    Windows XP Home SP2
    WD1200JD SATA
    nVidia 6800 GT
    Turbo-Cool 510 PSU
    Lite ON 16X DVD
    Sony 40-12-48X
    SB Audigy Gamer
    1.44 Floppy
