Author Topic: B450 tomahawk issue check the video  (Read 220 times)
60mpgphTopic starter
  • STAFF SERGEANT
« on: 17-January-20, 02:53:04 »
Hi all
could you confirm that this issue like is on  the video from july 2019 is solved with latest bios update. I had similar issues 2 days ago and found this video later when i sent the motherboard for repair. Also couldnt make to work waking up computer from sleep mode. When i pressed mouse button to wake up computer  the mouse  had light on but didnt wake up computer.  Thank you
https://www.youtube.com/watch?v=YNINTGFcm8Q
plutomate
  • MAJOR GENERAL
Re: B450 tomahawk issue
« Reply #1 on: 17-January-20, 03:03:36 »
you can try to update the BIOS especially this BIOS comes with flash BIOS button so it's rather safe to do the BIOS update.
  • STAFF SERGEANT
« Reply #2 on: 17-January-20, 03:52:53 »
i have latest bios no doubt and i have tomahawk max board . Im using also recomended computer parts and despite it  i have similar issues like on video
  • STAFF SERGEANT
« Reply #3 on: 17-January-20, 03:56:07 »
my 1st post is not showing right for some reason. im asking if issue like is on video from july 2019 is solved with latest bios .thanks
  • STAFF SERGEANT
Re: B450 tomahawk issue check the video
« Reply #4 on: 17-January-20, 05:05:50 »
can you see the text in my 1st post. i see only link to video no text. its shambles
