Author Topic: Z390 Gaming Edge AC RAM Overclock  (Read 220 times)
wiggumonTopic starter
« on: 26-January-20, 12:21:39 »
I have the Z390 Gaming Edge AC and I am using Crucial RAM PartNo (BLE8G4D36BEEAK.M8FE1) which is on the supported RAM list for this motherboard. It runs at 2666Mhz by default, which is what the i7-9700k supports and it also has an XMP profile to run at 3600Mhz. When I enable the XMP, the system seems fine. I have run Prime95, Aida64, Memtest86, Memtest86+, and Windows Memory Diagnostic for multiple hours at a time and the system seems stable. The XMP profile sets the voltage at 1.35/6 but every so often I get a BSOD.
Using BlueScreenView-x64 to examine the crash dumps, it appears to be memory related and when I turn of XMP, all is well. I am wondering if I should manually set the BIOS to 3600Mhz with a 1.40v to see if that helps the BSOD problem as I feel like this is voltage related. There is a new, beta version, BIOS which I could try to see if that helps the XMP as well. Anyhow, any thoughts welcome.
-Chris
Chike
  • GENERAL
Re: Z390 Gaming Edge AC RAM Overclock
« Reply #1 on: 26-January-20, 13:31:41 »
It may not be related to the ram at all.
Try +0.025 vcore voltage offset.
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
« Reply #2 on: 26-January-20, 20:48:22 »
Thanks, Chike. I'll try the vCore offset and yes, it may not be RAM related at all. Maybe just some voltage adjustments will resolve this.
-wigg
Chike
  • GENERAL
« Reply #3 on: 26-January-20, 20:52:16 »
We know there is a voltage problem with some of z390 boards, but it may depend on the cpu as well.
Mainly at low load.
CPU: i5-4670k
