Author Topic: Problem overclocking with MSI B450 Gaming Pro Carbon AC  (Read 606 times)
zachauzTopic starter
I'm running Ryzen 5 1600 on my B450 Gaming Pro Carbon AC with G.Skill 16gb (2133) RAM, Asus ROG Strix RX 570 4gb OC. From what I understand,using the Ryzen Master to overclock is a great way to get the sweet spot for the OC settings so as to enter it manually in the BIOS and get the OC to be permanent. I overclocked the CPU to 3.9 GHz on stock cooler and it has been running stably with absolutely no issues.
The problem is that when I enter the values manually in the BIOS,it doesn't work. My BIOS is updated to the latest,so are all my chipset and motherboard drivers. I'm quite new to overclocking and can't seem to get it working even after playing around with all the recommended settings I've read and come across.
Any help would be really appreciated ;D :worship:
  • T9246ED
  • Administrator
Re: Problem overclocking with MSI B450 Gaming Pro Carbon AC
« Reply #1 on: 16-February-20, 17:00:04 »
What happens exactly?
Which settings did you modified in BIOS?
« Reply #2 on: 04-March-20, 09:56:26 »
I noted down the values after overclocking with ryzen master such as :
      CPU Ratio
      CPU Core Voltage
      CPU NB/SoC Voltage
and I change them in the BIOS. When I save the settings in the BIOS and restart the PC,the BIOS just resets the CPU Ratio to default settings and is not overclocked.
Enabling or Disabling A-XMP gives the same result.
twinshadows
« Reply #3 on: 01-April-20, 08:02:41 »
As far as I know, Ryzen master keeps C and P states.
After changing the CPU multiplier AMD Cool’N’Quiet will be turned off.
You can re-enable it under CPU features.
Also you can go step by step with the multiplier before changing any voltages.
Does it reset if you just change CPU multiplier to say 39 and leave everything else on AUTO?
Main Board: MSI B450 Tomahawk
Bios Version: 7C02v1D
Video Card: MSI RX 480 Gaming X
PSU brand and model: XFX TS650
12v rail Rating of listed PSU: 54A
CPU: AMD Ryzen 2600
Memory: 2x8GB, 3200MHz Hyperx HX432C16PB3K2/16
SSD/ HDD: 1TB Sandisk WD Black 2018/PC SN720 NVMe SSD, 1TB WDC WD1003FZEX-0 HDD
CPU COOLER: MSI Core Frozr XL
OC: Yes
Operating System: OpenSUSE Tumbleweed
