Author Topic: Can't manually overclock on TRX40  (Read 312 times)
jeffripperTopic starter
« on: 18-February-20, 13:31:04 »
Recently got a TRX40 Pro 10G and Threadripper 3960x. I can't find anywhere or any way to change the multiplier... it is always greyed out. The only thing that works is using OC Genie for the 400MHz boost. I have read the manual and haven't found anything useful. Online explanations of OC with other similar boards show changing things I can't change.
Help?
  • 微星科技
Re: Can't manually overclock on TRX40
« Reply #1 on: 18-February-20, 14:24:46 »
Have you tried +/- keys of numpad to change core ratio?
AMD Ryzen 9 3900X
Windows 10 Pro
« Reply #2 on: 18-February-20, 15:09:25 »
I can't select the multiplier field, period.
*I'm also running Linux so any Windows stuff is not helpful
Chike
  • GENERAL
« Reply #3 on: 18-February-20, 15:35:05 »
Have you cleared cmos and start fresh?
CPU: i5-4670k
Cooler: CNPS10x Performa
Memory: F3-2400C11D-16GXM
HDD: WDC WD3200AAKS-00L9A0
PSU: Antec 500W VP500PC
Case: Compucase 6C60
« Reply #4 on: 18-February-20, 18:57:46 »
I did when I updated to latest BIOS, which I thought might help. No matter what I change, I can never change CPU Ratio from Auto. It will also not use any boost. No matter what, it would stick flat at 3800MHz across all cores.
Chike
  • GENERAL
« Reply #5 on: 18-February-20, 19:04:40 »
Ask msi >>How to contact MSI<<
Which bios versions have you tried?
CPU: i5-4670k
« Reply #6 on: 18-February-20, 19:24:30 »
I think it came with V1.0 and I applied latest 1.2
« Reply #7 on: 23-February-20, 21:54:56 »
MSI support provided me with a 1.35 BIOS to try.
- The multiplier can be changed now when Genie is off, and I have a successful manual overclock.
- Now enabling PBO causes the CPU to run at 2800MHz, regardless of the settings used.
Weird.
