Author Topic: I can't find FCLK option on B450 Tomahawk MAX  (Read 456 times)
serdarmiyTopic starter
« on: 22-February-20, 04:46:45 »
Hi guys, I have B450 Tomahawk MAX and Corsair CMW16GX4M2C3000C15 RAMs. I use my RAM with 3200 MHz 15-17-17-35 1.35V. I want to change my FCLK option but I can't find it. Can you help me? I have updated my BIOS just now.
pkpatu2016
Re: I can't find FCLK option on B450 Tomahawk MAX
« Reply #1 on: 23-February-20, 06:55:26 »
I have a b450 tomahawk max that doesn't work well with ram. I have two memories (2x16gb ddr4 3200mhz .. Features: - Brand: Rise - Model: RM-D4-8G-3200D   Specifications: - Capacity: 16GB - Frequency: 3200Mhz - Type: DDR4 - Frequency: 3200 - CL15–17-17-35 1.2V - Latency: 15 - Pinout: 288 pin DIMM   Package content: - Diamond Rise Mode Memory) activates xmp on A1b1, does not work activating xmp on A2b2 .. even with xmp active it only works 2400mhz.setando manual, with voltages, nor beep. Another card with another ryzen processor got normal. I upgraded and changed the card no longer takes 3200mhz
plutomate
  • MAJOR GENERAL
« Reply #2 on: 02-March-20, 23:39:29 »
@serdarmiy i think you'll need to use ryzen 3000 CPU to have to option to change fclk, other CPU does not have such function.
@pkpatu2016 you should always populate A2B2 slot first, feel like your memory is not being stable with high frequency, can you list you system configuration? CPU and stuff, and also attach a picture of the sticker on your memory that shows the model name and manufacture date
