Author Topic: Where is VDDG setting on MSI X399 GAMING PRO CARBON AC?  (Read 201 times)
elliot.manning01Topic starter
This thread on reddit addresses my issue of popping(crackling) audio I occasionally encounter.
https://www.reddit.com/r/MSI_Gaming/comments/el6e8m/psa_audio_poppingcrackling_potential_fix_for/
But I don't see VDDG anywhere in my BIOS settings.  Additionally, would the recommended voltage increase be different since I have a Threadripper 1950X?
Is it the same as VDD_SOC in Command Center?
https://imgur.com/a/muNpoOc
Re: Where is VDDG setting on MSI X399 GAMING PRO CARBON AC?
« Reply #1 on: 27-February-20, 18:50:20 »
Fundamentally, XMP 3200 RAM overclock is just going to push your RAM voltage to 1.35. (DDR3 ran at 1.5V, so this "overvoltage" at 1.35 is quite safe and still relatively power-efficient). Your motherboard will also push the voltage on AMD's infinity fabric a bit higher (Vdd_soc to 1.1V).
https://techreport.com/forums/viewtopic.php?t=121531#p1395489
Ok, it is the same as VDD_SOC.  I bumped mine to 1.200 from the default 1.150 setting and hopefully that'll put an end to the crackly/popping audio altogether.
