Author Topic: BLCK overclock stabilty  (Read 137 times)
twinshadowsTopic starter
« on: 31-March-20, 10:17:10 »
On a previous BIOS(ver. 7C02v1B) I overclocked the BLCK and it seemed stable.
After a week or two the BIOS would reset to stock setting .
Then my NVME started printing errors like this:
Code: [Select]
[108972.972364] pcieport 0000:00:03.0: AER: Multiple Corrected error received: id=0018 [108972.972393] pcieport 0000:00:03.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, id=0018(Receiver ID)
[108972.972398] pcieport 0000:00:03.0:   device [8086:2f08] error status/mask=00000040/00002000
[108972.972402] pcieport 0000:00:03.0:    [ 6] Bad TLP
I wonder if anyone archived a stable BLCK overclock and is it safe to push it higher without risking damage to the SSD.
Thank you in advance.
Edit: typos
Main Board: MSI B450 Tomahawk
Bios Version: 7C02v1D
Video Card: MSI RX 480 Gaming X
PSU brand and model: XFX TS650
12v rail Rating of listed PSU: 54A
CPU: AMD Ryzen 2600
Memory: 2x8GB, 3200MHz Hyperx HX432C16PB3K2/16
SSD/ HDD: 1TB Sandisk WD Black 2018/PC SN720 NVMe SSD, 1TB WDC WD1003FZEX-0 HDD
CPU COOLER: MSI Core Frozr XL
OC: Yes
Operating System: OpenSUSE Tumbleweed
