Author Topic: Help no results  (Read 1494 times)
mroland
Help no results
« on: 23-November-03, 14:20:50 »
According to the instructions provided in the manual I have correctly connected the motherboard to the components correctly.  The problem is, when i turn it on, the only thing to work is the processor fan.  I have checked and the power supply is working (connected it to fans and fans came on) but nothing else is.  Here is what I have
KT8 Motherboard
amd 3200+ processor
Maxtor 200gb SATA drive
ati 9800xt
cd rom
512mb memory
Floppy
That is all i have hooked up
also if i hook up the JPW1 to the powersupply it powers down.  according to the book, it should be hooked up.
Thanks
Mike
