Author Topic: Serial number needed for MSIPVS  (Read 4042 times)
wing
« on: 10-December-03, 03:11:47 »
I bought a OEM barebones TV @nywhere Master and it did not come with the serial number which is required to install MSIPVS.  How do I work around this?  Without installing MSIPVS, the TV tuner does not work properly.
Glenn
  • GENERAL
  • Former Moderator
« Reply #1 on: 10-December-03, 04:00:53 »
  • Best Answer
  • Did you look on the CD?
    msi P55-GD65
    i7-860 Lynnfield
    G.SKILL Ripjaws Series 8GB (4x2) DDR3 1600 (PC3 12800)
    Zalman CNPS9900A LED CPU Cooler
    Diamond Radeon HD 3870 512MB GDDR4 Ruby Edition
    Acer X203w 20" LCD
    Samsung LN-T3253H 32" LCD HDTV
    Kingston 128GB SSDNow V-Series
    WDC Blue WD5000AAKS-22A7B2 500GB
    Sony DRU710A DVDRW
    Logitech Z-5500's
    Creative Audigy2 ZS
    Antec 300 Case
    PCP&C Silencer 500 EPS12V PSU
    Windows 7 (64bit)
    conio
    • FIRST LIEUTENANT
    • Zzzz Zzz Zz
    « Reply #2 on: 10-December-03, 16:26:32 »
  • Best Answer
  • Actually the tuner works great witout MSIPVS ...
    all you really need are the drivers
    System:
    ASUS P5Q
    E6600 Core 2 duo
    6G RAM
    Gigabyte NX88T512HP GF8800GT 512MB
    MSI TV-@nywhere Master
    Seagate Baracuda 120G, 8M cache -> went external
    Seagate ST3250410AS
    Seagate ST31500341AS
    WDC WD2500JS
    WDC WD5000AAKS
    NEC ND-3540A
    Samsung SyncMaster 959NF :like: :like: :like:
    Antec Performance TX1088AMG   :agrees:
    Corsair VX550
    Logitech Z640  :dance:
    OS:WinXP & Windows 7 x64
    wing
    « Reply #3 on: 12-December-03, 21:00:36 »
    I didn't get a CD. the package conained just the card and nothing else.
    I use VirtualVCR and it works the tuner but it won't let me record the channel I set to.  It always resets to channel 2 when I exit the tuner controls.
    Another reason why I want MSIPVS to work is because I want to use the scheduler.
    conio
    • FIRST LIEUTENANT
    • Zzzz Zzz Zz
    « Reply #4 on: 15-December-03, 07:42:21 »
  • Best Answer
  • I don`t use the MSIPVS scheduler because it ALLWAYS gives me BSOD`s. :wall: :angryfire: o_0 :frankie:
    as for VirtualVCR is has command line options so you can use the windows scheduler ... just write the commands line options.
    System:
    ASUS P5Q
    E6600 Core 2 duo
    6G RAM
    Seagate ST3250410AS
    WDC WD2500JS
    WDC WD5000AAKS
    NEC ND-3540A
    Corsair VX550
