Author Topic: Sound problem  (Read 1381 times)
AnatolibusPectis
Sound problem
« on: 13-December-03, 06:36:50 »
in some case, my audio device hang-up...no windows crush, no device problem reported in control panel but simply NO SOUND.
i have tried to install realtek new audio driver sometimes but the problem is there...
if i use audio it work ok but if i do other, in some case my audio device stop to work
anyone have solution?
joshr45
(No subject)
« Reply #1 on: 15-December-03, 23:13:42 »
the problem that i have found is that when u use the MSI Live update 3 or the Live monitor and it checks the drivers it stops the sound thats just about all the problems i have
