Author Topic: K8T Neo memory test  (Read 1594 times)
cromus
K8T Neo memory test
« on: 14-December-03, 16:34:19 »
Hi  all  just   wanted to  know   is  there  anyway  to disable ecc checking  in my  mobo  bios  cos  i have  looked  and  i can,t see  anything  that  mentions  anythingalso  does  anyone  know  of  any  issues  between the  FX5950 and  this  board  as  my  games  crash all  the  time    i will  b playing  them  then  they  just  freeze  and  everything locksout   the  only  way  back  into  the  system is  to  reboot  , i wanted  to  turn ecc checking  off  because  i want  to  run memtest86  to  see if  my  ram  is  up to  scratch  :help: :wall:
scottg26
(No subject)
« Reply #1 on: 14-December-03, 16:47:30 »
memtest86 doesn't even start for me. it loads, then restarts the PC.
We kinda need your system specs as well if you want to have any help with your problem...
cromus
(No subject)
« Reply #2 on: 14-December-03, 17:03:11 »
:oops: sorry  system is  comprised of
  AMD64 3200+
K8T NEO-FIS2R ATHLON64  mobo ( bios date  02.04.01 ?) (mobo bios version 07.00t?)
256MB LEADTEK FX5950 ultra/ tdh/my vivo
 x2 256mb of samsung  pc3200 ddr 400 cl3
120gig hd
x16 dvd/cdrom
nec multiformat nd1300 +/- dvd rw/cdrw
5.1 audio
creative 6700 speakers
xp home
jeantech 350w psu
scottg26
(No subject)
« Reply #3 on: 15-December-03, 04:04:25 »
just a quick question, if you can't find the option for ECC then how did you turn it on? ???-) ???-)
