Author Topic: Opinions on "Plug & Play Aware O/S" setting? (BIOS)  (Read 3198 times)
GrunbergTopic starter
  • SECOND LIEUTENANT
    • Grundage!
« on: 17-December-03, 18:05:57 »
In the BIOS, there's a setting for "Plug & Play Aware O/S". Is it safe to turn this on for a system running Windows XP Home?
THE MEAT IN MY HOG:
- Antec 400W PS
- MSI K8T Neo FIS2R (BIOS v1.9)
- AMD Athlon 64 3200+ CPU
- MONITOR: 19" Samsung 930B, 1280x1024 res
- HARD DRIVE (2): Maxtor 60GB 7200RPM Serial ATA
- CD DRIVE: Sony 52x32x52 DVD-ROM/CD-RW
- VIDEO: ATI Radeon 9600XT, 128MB AGP
- MEMORY: Corsair 1GB PC-3200 DDR
- OS: Windows XP Home SP2
- Dave
scottg26
(No subject)
« Reply #1 on: 17-December-03, 18:50:53 »
don't know, i just have always left it off for every system i have setup/built
Jocko
Plug'n'nplay
« Reply #2 on: 17-December-03, 20:22:13 »
Hi
All our machines are set with this on, it lets them find and load all equipment plugged into USBs etc.
Ex Forum User 3
(No subject)
« Reply #3 on: 18-December-03, 02:43:03 »
PnP OS is for Win9x/ME....
It's best to let is stay off for any higher Windows version then those....
Bibihest
  • SECOND LIEUTENANT
    • http://vivaldi.dk
(No subject)
« Reply #4 on: 18-December-03, 03:09:49 »
I think, if the option is ON, Windows will give IRQ's to all PnP things. If it's off, the BIOS will do that instead
Ex Forum User 3
(No subject)
« Reply #5 on: 18-December-03, 03:32:59 »
With Win9x/ME that's the way it works.....
NT/2000/XP can get into trouble (not saying they must!) when this setting is on.
Anyway, PnP OS setting only applies to ISA cards as far as I know, so it has very little use anyway.
Bibihest
  • SECOND LIEUTENANT
    • http://vivaldi.dk
(No subject)
« Reply #6 on: 18-December-03, 04:56:19 »
I've been looing around the net to find some more info on this one, but didn't find much.. But Bas is right about this one :biggthumbsup:
Plug and Play Aware O/S:
No for Windows 2000/Windows XP and newer
Yes for Windows 98/ME
And Microsoft recommends NO, so think I will change mine to no :idea:
