Author Topic: Standard Enhanced PCI to USB host controller?  (Read 1935 times)
Namron
« on: 22-December-03, 12:01:56 »
When I take a look in my Device manager I have an exclamation mark with a yellow background in front of Standard Enhanced PCI to USB host controller. When I try to install the hardware/update it, it tells me it can't do it since it doesn't find it. What is this about? Is it something I need? Can I uninstall it and reboot and have it installing itself properly?
Thankful for any help.
DrArcHeH
« Reply #1 on: 22-December-03, 12:29:17 »
You might want to try to install the Intel INF Update Drivers, using LiveUpdate or download them directly from Intel
Wonkanoby
« Reply #2 on: 22-December-03, 12:35:42 »
  • Best Answer
  • if you plugged in any case usb bits try with them removed
    P5Q Deluxe
    Intel QX 6700
    4GB OCZ
    60 GB Vertex drive
    ATI 5850
    Namron
    « Reply #3 on: 22-December-03, 13:12:32 »
    Thanks. That solved it!  :biggthumbsup:
