Author Topic: FastTrak (promise) Bios Probs - Raid  (Read 1647 times)
UTSAzn
« on: 04-January-04, 11:57:50 »
Ok Now i just recently got this mobo and i've been reading up, but to no avail. The problem is that i had an extra HDD that sat on the raid ide and i could use it just fine. well now i can't get access to this drive when i plug it into the raid ide slot on the mobo. I've installed all the raid drivers i could find for this mobo but they all seem to support SATA, and another prob is that  during the boot sequence the FastTrak bios boots but then says bios not installed and just skips it. So is there an update or an install for this bios that i cant find? Any help or suggestions are much appreciated! Thanks.
