Author Topic: dbracket LED complete Listing  (Read 2320 times)
eazyc10
« on: 15-January-04, 23:04:45 »
I'm just wondering where I can find a complete listing of the 16 combinations of LEDS for the d bracket.  I currently have an issue with 1-red and 2,3,4-green.
System is kt8, a643200, antec 430 true power, kingmax pc3200 ram
The thing is I installed this machine without any hiccups for my cousin, booted up perfectly out of the box and installed windows.  When I gave it to him, the next day it's broke, not booting.  Not sure what the deal is.
scottg26
(No subject)
« Reply #1 on: 15-January-04, 23:21:50 »
It is in the manual on page 1-11 to 1-12
eazyc10
(No subject)
« Reply #2 on: 15-January-04, 23:23:48 »
I actually don't have the manual with me since I'm just fixing the computer for my cousin, i downloaded the manual though and it seems to be incomplete.  Thanks though
eazyc10
(No subject)
« Reply #3 on: 15-January-04, 23:36:07 »
well got it finally to boot up to the cd but now when I'm trying to install xp it says "Line 16570 of the INF file \i386\txtsetup.sif is invalid"  I know the cd works since I booted it up on another computer and it worked fine, plus it's the same disc I used to install xp on the machine before.
I was looking at the first couple lines of the file and appears to have files for certain types of processors to load during installation.
scottg26
(No subject)
« Reply #4 on: 16-January-04, 01:22:35 »
i have the online version of the manual too and it seems to be missing page 1-12 (its blank)
felixthecat
(No subject)
« Reply #5 on: 18-January-04, 10:47:08 »
if your using acrobat to read it you may need to update acrobat texts/grapgics it to see all pics properly, i was prompted to do so whilst online when checking the online manual b4 buying it eventually
Wonkanoby
(No subject)
« Reply #6 on: 18-January-04, 10:50:28 »
  • Best Answer
  • for me it asked to install some chinese support language bit,after saying yes it all was ok
    P5Q Deluxe
    Intel QX 6700
    4GB OCZ
    60 GB Vertex drive
    ATI 5850
    Wonkanoby
    (No subject)
    « Reply #7 on: 18-January-04, 10:53:37 »
  • Best Answer
  • Logged
    P5Q Deluxe
    Intel QX 6700
    4GB OCZ
    60 GB Vertex drive
    ATI 5850
