Author Topic: K8T Neo boot only without keyboard  (Read 2645 times)
Waryu
« on: 16-January-04, 13:10:35 »
since yesterday I am owner of an MSI K8T Neo Mainboard, but unfortunately I can't enjoy it. The mainboard boots only sometimes an only if the keyboard is not connected.
My system:
Mainboard: MSI K8T Neo-FIS2R (MS 6702 Ver. 1.0)
Prozessor: AMD Athlon 64 3000+
Cooler: Artic Cooling Silencer 64
RAM: Infineon 2100er DDR RAM (HYS64D32000GU-7-A, A3E115011, PC2100U-20330-B1. CL2)
Graphic card: ATI Radeon 8500 64 MB
Power Supply: Enermax EG465AX-VE(G) FMA 460 W (+3.3V: 35A, +5V: 35A, +12V: 33A)
While I'm trying to find the problem I 've already try to:
- running the mainboard outside of te case to avoid shortcircuits
- reseting CMOS
At the moment the mainboard is lying on a piece of newspaper, only the processor, the cooler, the power supply (both power connectors, even the 4-pin 12V connector), the graphic card, the power switch and the diagnose LEDs (D-Bracket 2) are connected.
If I power on the system, I get to the boot screen, where the system want's me to hit F1 or F2 to configure the reseted CMOS, but thats difficult without  a keyboard...
If I connect the keyboard (PS/2), the first boot screen stays on the display (the CoreCell Ship logo, no texts) and the d-bracket shows "attempt to boot". I tried 3 different PS/2 Keyboards (one Cherry Keyboard and two NoName products), but it's every time the same effect.
I already tried to fit only one of the Infineon RAMs into the motherboard, but nothings changes.
Is there someone who can help me? What else could I try?  ;-((
Greetings
Henning
Ex Forum User 3
(No subject)
« Reply #1 on: 16-January-04, 13:21:12 »
  • Best Answer
  • I would say, check the standoff's between the board and the case.....
    Maybe they are shorting some circuits?
    Also, have you tried without a mouse connected?
    Waryu
    RE: K8T Neo boot only without keyboard
    « Reply #2 on: 16-January-04, 13:36:46 »
    The board is outside the case. No possibility for a short circuit.
    I try to connect a mouse/keyboard kombination:
    ps/2 keyboard connected: no boot
    ps/2 keyboard/ usb mouse: no boot
    ps/2 keyboard/ ps/2 mouse: no boot
    only usb mouse: no boot
    only ps/2 mouse: no boot
    nothing connected: boot
    b.t.w. the d-bracket shows "attempting to boot" after it shows "bios sign on (this will start showing information about logo, prozessor,...)"
    Greetings
    Henning
    Waryu
    (No subject)
    « Reply #3 on: 16-January-04, 14:17:58 »
    Another information: the lights on the keyboard doesn't blink on power up.
    Should I return the board to the dealer and try another one?
    Greetings Henning
    Jocko
    Not booting
    « Reply #4 on: 16-January-04, 19:31:54 »
    Hi
    Do you have a HDD connected? - is a floppy conected, it won't boot on its own.
    cheers
    Waryu
    RE: Not booting
    « Reply #5 on: 18-January-04, 11:31:42 »
    no, i don't have a hdd connected. I think, the board should boot with keyboard connected to the point where it's boots to, when nothing is connected, or not?
    Greetings
    Henning
    Ex Forum User 3
    (No subject)
    « Reply #6 on: 18-January-04, 13:47:05 »
  • Best Answer
  • Exchange the board, I think the Keyboard controller is broken....
    No other way I can explain this.
