Author Topic: cpu probe?  (Read 1492 times)
felixthecat
cpu probe?
« on: 18-January-04, 09:22:21 »
one more question,
my new case has some temp probes that give readings on a front display for the sys/cpu and DH , they are like loops of wire, I had one previously on an xp system, connected to the fan and was placed under the cpu. so as to controll fan speed
 If i wanted to use the case probes would this be safe for the athlon 64,where would i place it,  also does one need a new insulating material if changing cpu in future? I could live without it and just attach it to another HD instead because corecenter is great
