Author Topic: Overclocking Guide  (Read 138895 times)
Kingfisher
Overclocking Guide
« on: 01-February-04, 13:07:32 »
Overclocking Guide
Disclaimer: Overclock at your own risk!
Data and information provided in this guide are for informational and educational purposes only, and are not intended for trading purposes. Neither MSI nor any of this thread’s authors shall be liable for any errors or delays in the content or be held responsible for any damage caused by modifying or overclocking your computer. Manufacturers may or may not honor the warranty on any overclocked or modified computer components. Perform any modifications to your systems at your own risk.
Why Overclock?
Today, overclocking is not any secret. It has become more popular and almost become an addiction to some people. The definition of Overclocking is simple: it means operating an Integrated Circuit beyond its specified clock speed.
But why overclock? Some people say to get more out for the same money. “It’s there; why not get more out of it?” However, the best business reason for overclocking is that it can make “out of date” equipments useful again. If the equipment is already out of warranty, the risk is very limited. (I personally suggest any beginners to overclock any out of date PC first just to have some first time experience.)
Know more about the Central Processing Unit (CPU)
Processor speed is based on two factors. The first is the interface between the motherboard and the front side bus (FSB). From http://en.wikipedia.org/wiki/Main_Page (Wikipedia, the free encyclopedia), FSB is the speed at which the CPU communicates with RAM (memory). Many system components - including the PCI and AGP buses usually run at speeds derived from the frontside bus' speed. In general, a faster frontside bus means higher processing speeds and a faster computer. The other factor controlling a CPU's speed is the clock multiplier. It defines the ratio of processor speed to the FSB.
The FSB on new processors ranges from 400 MHz to 800 MHz. These are not straight clock speeds but instead they are quad-clocked speeds. These processors actually transmit data four times per clock cycle, for example, 800 MHz FSB is actually four times the 200MHz clock (200 MHz x 4 = 800 MHz).
The core speed of the CPU is the product of the front side bus clock and the multiplier. A processor running at 3600MHz (i.e. 3.6 GHz) might be having 800 MHz FSB, this means there is a clock multiplier setting of 4, and thus the CPU is set to run at 4 times the MHz speed of the front side bus.
But we said earlier that they are quad-clocked speeds, so 3600 MHz actually came from 18 times 200 MHz (200 MHz x 18 = 3600 MHz).
Please note that not all processors have quad-clocked speed FSB. For example, the Intel Pentium 4 (Northwood core) has quad-clocked speed FSB. But for example, the Intel Pentium III, AMD Athlon XP and AMD Duron have dual-clocked speed FSB only.
To know more, please read:
http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2178
Let’s lock the clock multiplier
Few years ago, you could overclock processors by choosing a higher multiplier. This option was eliminated in order to fight CPU remarking. Counterfeit processors have regularly appeared in the market, as the CPU speed was only defined by your setting. Nowadays, the restriction to only one multiplier is both of overclocking and counterfeit prevention.
As you can see, the only way of overclocking today is choosing a higher front side bus clock and the offer of small increments e.g. 1MHz in today's motherboards give us a great advantage in overclocking.
However, some CPUs nowadays are still unlocked, for example, the AMD Athlon MP and AMD Athlon64 families. And some motherboard companies offer the chance to unlock the Pentium 4 (Socket 775 CPUs only) overclocking potential by using special bios, for more please read:
http://www20.tomshardware.com/motherboard/20040916/index.html
Look at your motherboard
Before you overclock anything, have a look if your motherboard can overclock CPU. Look at the CPU installation section in the motherboard manual. Normally you will find either BIOS setup options or jumpers on the motherboard that allow you to adjust the FSB, CPU voltage, PCI/AGP ratio etc.
If you have a computer that came from a major manufacturer like HP, it is likely that your motherboard does not provide any overclocking function although it is very rare nowadays.
You need more Power!
This is also the time to check the power supply in your computer. Like a car, speed requires power, and unstable power inevitably leads to unstable processors, so I would recommend the power supply has to be at least 350 Watts. You can find six power supply guides in this forum below:
A Power Supply Guide
AND
Powersupplies(Written by Bas)
AND
Choosing The Right Power Supply
AND
Powersupply calculation....
AND
http://www.extremeoverclocking.com/articles/guides/Power_Supply_Guide_1.html
Both Intel and AMD processors are power hungry, consuming 40 to 100 watts (e.g. the new Prescott) of power. Also, your graphics card may take another 55 watts of power. Now you are consuming more than 100 watts of power for merely two components in your system.
You can also voltmod your Power Supply Unit, for more please read:
http://www.xbitlabs.com/articles/other/display/psu-voltmodding.html
Using higher voltages
Today, almost each processor can be run faster than the speed it was labeled for. This applies even more if you raise the core voltage a little bit. This is just like a car running at higher speed requires more power. But this is one of the “riskiest” aspects of overclocking - by using too much power you could burn your CPU. You should always raise the voltage step by step and never go higher than 15% beyond the specification. This way it is quite easy to get a faster system without risking the processor. Apart from raising the voltage of the CPU, similarly you can raise the voltage of memory as well. One problem is of course the increasing chip temperature, so cooling is very important. We will cover that later.
Memory Speed
Memory speed is often tied to the FSB. For example, a Double Data Rate (DDR) 400 memory has frequency 200MHz and the module rating is PC3200. Half the performance increase you may see from overclocking a CPU comes from increasing the speed at which the processor can talk to the memory.
When you buy memory, you may see it has label 2-3-3-7-1T. And you may also hear people saying my memory is a 2-3-3-7 one. But what does it mean? The answer is:
CAS Latency = 2 clock cycles
tRCD = RAS to CAS delay = 3 clock cycles
tRP = RAS Precharge = 3 clock cycles
tRAS = Active to Precharge = 7 clock cycles
Command Rate = 1 clock cycle
Different motherboards may call the above differently and not all of them will appear in the BIOS. You may need to check with your motherboard’s support team and the motherboard manual. If you have any option above in your BIOS, you can also start to adjust them. Obviously, the smaller the number the faster the memory will be.
To know more about memory please read:
http://www.corsairmicro.com/corsair/products/tech/memory_basics/153707/index.html
AND
Memory Roundup
AND
http://www.anandtech.com/memory/showdoc.aspx?i=2223
Video Card
To overclock video card, we need a third party utility to overclock the card. Although increasing numbers of manufacturers include utilities to allow customers to overclock their cards in their drivers or through an extra application, most of them do not provide this facility. Simply because overclocking stresses the system and voids manufacturer warranties. Third party utilities tend to be universal that they work on different cards irrespective of manufacturers.
Some utilities and the places to download included:
1. OMEGA Drivers
http://www.omegacorner.com/
2. StarStorm Drivers (Nvidia cards only)
http://downloads.guru3d.com/download.php?id=10
3. RivaTuner
http://www.guru3d.com/
4. PowerStrip
http://www.entechtaiwan.com/
5. Rage3D Tweak (ATI cards only)
http://www.rage3d.com/index.php?node=r3dtweak
6. RadLinker (ATI cards only)
http://www28.brinkster.com/chrisww1942/
7. ATITool (ATI cards only)
http://atitool.ocfaq.com/
Please read their own manuals in their corresponding web pages. Also, if you want to be able to have the hidden functions in Nvidia card, create a file with notepad and put this in it (thanks for Deathstalker to provide this source):
[HKEY_LOCAL_MACHINE\SOFTWARE\NVIDIA Corporation\Global\NVTweak]
"Coolbits"=dword:ffffffff
"NvCplEnableHardwarePage"=dword:00000001
"NvCplEnableAGPSettingsPage"=dword:00000001
Save it as agpsetting.reg to your desktop or anywhere you like. Then run it and it will give you all the hidden options from Nvidia which include extra resolution settings for your desktop and overclocking for both the memory and core.
For ATI Radeon X800 Pro softmod, please read (link provided by mopey):
http://www.ocforums.com/showindex.php?t=312063
For ATI Radeon X800 Pro voltage mod, please read (link provided by NovJoe):
http://www.vr-zone.com.sg/?i=817&s=1
For ATI Radeon 9800 XT voltage mod, please read (link provided by NovJoe):
http://www.vr-zone.com.sg/?i=760&s=1
To can change your Radeon 9800 Pro 256MB graphic card to Radeon 9800XT card, please read (in English):
http://www.rojakpot.com/(jiljtv55hwgq5uabzft0f5re)/default.aspx?location=3&var1=92&var2=0
To change your GeForceFX 5900 graphic card to GeForceFX 5900 Ultra, please read (in Traditional Chinese):
http://www.oc.com.tw/article/0403/readocarticle.asp?id=2410
To change your GeForceFX 5700 Ultra graphic card to QuadroFX 1100, please read (in Traditional Chinese):
http://www.oc.com.tw/article/0403/readiyarticle.asp?id=2387
Get the temperature down
Cooling is probably the most important aspect of overclocking. Overclocking causes circuits to cycle faster, generating more heat. If the CPU is not cooled properly, your CPU will not run reliably and there is a very good chance that you will permanently damage your CPU.
The heat sink and fan unit that Intel and AMD ship with its CPU are fairy good. However, for maximum stability, we need to get something better than that. For example, for CPU fans, we have Vantec Tornado, Thermaltake volcano 7+, CoolerMaster Aero 4 and Zalman CNPS7000A-AlCu etc.
Be sure that the cooling solution you choose is specifically designed for your processor. Improperly mounting a heat sink, using the wrong model can damage your processor.
Also, the airflow in the case is very important. If heat cannot escape the case, the CPU is still at risk. Thus, more case fans are needed apart from the power supply's exhaust fan. Tidying up the cables inside the case can help too. In addition, clearing the dust in the case by using canned compressed air can enhance the airflow but never use vacuum cleaner as it may generate electrostatic and harm the IC components.
For more about cooling, you can also read these:
http://www.antec-inc.com/pdf/article/info_DIYArticle3.html
AND
http://www.antec-inc.com/pdf/article/info_DIYArticle2.html
AND
Cooling guide(Written by J*A*G)
AND
http://www.community.tomshardware.com/forum/postlist.m?Cat=&Board=over_cooling
For more about CPU fan, please read:
BEST Overclockers CPU cooler????
For more about Water Cooling, please read:
Water cooling...
Keep the Noise Down
Unless your computer is cooled by a water cooling system, it will be pretty noisy. To keep the noise down, please read this:
http://www.antec-inc.com/pdf/article/info_DIYArticle_quiet_computing.html
Overclocking Process
Essentially, overclocking processors consists of increasing the FSB in the BIOS, booting the computer, and then testing for stability. You repeat the process until you identify the maximum stable speed.
In case your board offer 1 MHz-increments (which most of your boards do), you have the chance to find out the maximum clock speed by slowly closing in on the final limit MHz for MHz. Of course this cannot be done in an hour, but you will have to spend one or two days just playing with different clock speed settings. In the end you should have your CPU running at the highest possible core speed. The Most important thing to remember is that you must go Slowly!
Also, you can overclock the processor by using software although it may not be as effective as overclocking using the motherboard BIOS. Such software includes:
1. ClockGen
http://www.cpuid.com/
2. CPUFSB
http://mitglied.lycos.de/podien/
3. 8rdavcore
http://www.hasw.net/8rdavcore/
Here is a thread that talks about overclocking an Intel Pentium 4 2.4cGHz to 3.0GHz using Intel 865PE chipsets. (You may treat it as an example of overclocking.):
Best 865PE Overclock for 2.4C to 3.0+
Changing the FSB is a relatively simple matter of entering the computer's BIOS setup screen, switching from automatic to manual configuration and selecting the FSB speed you want. Here are some utilities that you can check your computer’s setting, especially CPU speed:
1. CPU-Z
2. WCPUID (Linux supported)
http://www.h-oda.com
3. AIDA32
http://www.aida32.hu/aida32.php
http://aumha.org/freeware.htm
4. PC Wizard
5. EVEREST
http://www.lavalys.com/
6. Motherboard Monitor
http://mbm.livewiredev.com/
7. HWiNFO and HWiNFO32
http://www.hwinfo.com/
8. SpeedFan
http://www.almico.com/
http://www.almico.com/speedfan.php
9. Motherboard Monitor
http://mbm.livewiredev.com/download.html
10. Intel Processor Frequency ID Utility (Intel CPU only)
http://support.intel.com/support/processors/tools/frequencyid/
11. AMD CPU Information Display Utility (AMD CPU only)
http://www.amd.com/us-en/Processors/TechnicalResources/0,,30_182_871,00.html
For more, you can go to the following to have a browse:
http://www.3degs.net/
Bear in mind that if the processor is capable of a 20-percent or more speed increase say, it is unlikely that your video card or memory can have the same amount of increase. And the one thing that you must remember to do if you overclock the FSB is to Set (i.e. Lock) your AGP/PCI Buses, to as close to their Default Frequencies as Possible (to PCI bus at 33 MHz and the AGP port at 66 MHz for example), or you will most definitely experience problems across the whole board e.g. your graphics card, onboard sound and IDE channels may start giving you data and other errors.
Test for Stability and Benchmarking
The purpose of testing is to apply a heavy workload to every aspect of your system to ensure that there are no hidden problems and stability issue. You can do testing by using special testing suites, software and games. The aim of benchmarking is to measure the performance of your system. In overclocking, benchmarking can tell you how far the system’s performance has increased when you adjust certain settings.
For a test suite, you may try Winbench, which you can download from:
http://www.etestinglabs.com/benchmarks/winbench/winbench.asp
Special software for testing and benchmarking included:
1. CPU Burn (Linux supported)
http://users.bigpond.net.au/cpuburn/
2. PCMark 04
http://www.futuremark.com/
3. Aquamark 3
http://www.aquamark3.com/
4. SiSoftware Sandra Standard 2004
http://www.sisoftware.net/
5. Prime95 (Linux supported)
http://www.mersenne.org/
(For more about Prime95, please read: how to use prime 95 properly)
6. Memtest86 (Linux supported)
http://www.memtest86.com/
7. Memtest86+ (Linux supported)
http://www.memtest.org/
8. Super PI (Linux supported)
http://pw1.netcom.com/~hjsmith/Pi/Super_Pi.html (Windows version)
http://ftp://pi.super-computing.org/Linux/super_pi.tar.gz (Linux version)
9. ScienceMark
http://www.sciencemark.org/
10. SETI @home (Linux supported)
http://setiathome.ssl.berkeley.edu/
For testing video card, you can run Games like Quake 3 and Unreal Tournament demo mode and left running in loops. You should be able to run a game in a loop for at least two hours after a reboot without a problem. Also, you can use 3DMark05 from FUTUREMARK (download from http://www.futuremark.com/).
1. Unreal Tournament (Linux supported)
http://www.unrealtournament.com/
2. Wolfenstein: Enemy Territory (Linux supported)
http://games.activision.com/games/wolfenstein/
3. Quake (Linux supported)
http://www.idsoftware.com/games/quake/
4. Call Of Duty
http://www.callofduty.com/index.asp
5. X2 - The Thread
http://www.egosoft.com/
6. Colin McRae Rally 4
http://www.codemasters.co.uk/colinmcraerally04/uk/colinmcraerally04.php
7. Nascar Thunder 2004
http://www.easports.com/games/thunder2004/home.jsp
8. Halo
http://www.microsoft.com/games/halo/
9. Farcry
http://www.farcry.ubi.com/
10. Half-Life
http://games.sierra.com/games/half-life/
11. Doom 3 (Linux supported)
http://www.doom3.com/
Tips: The benchmark can be performed by using “demo1” which ships with Doom 3. Open the console (Windows: Ctrl+Alt+~; Linux: ~) and type “timedemo demo1”.
12. Battlefield Vietnam
http://www.eagames.com/official/battlefield/vietnam/us/home.jsp
13. Serious Sam
http://www.serioussam.com/
14. Tomb Raider: The Angel of Darkness
http://www.tombraider.com/
15. Halo
http://www.bungie.net/
16. Tom Clancy's Splinter Cell
http://www.splintercell.com/
Conclusion
I suggest you to read this guide one more time before you overclock to make sure that you have not missed anything. Wish you have a good overclocking experience, have fun!  :biggthumbsup: Here is also another guide to make your have a Happier and Healthier System:
http://www.antec-inc.com/pdf/article/info_DIYArticle4.html
The following teaches you how to change an AMD Athlon XP 1700+ to an Athlon MP 1700+ (in Traditional Chinese):
http://www.oc.com.tw/article/0304/readocarticle.asp?id=1390
Also, for a Step By Step Overclocking Guide and other overclocking guides, you can go to:
1. General overclocking tips
2. more overclocking help
3. Hardware & Overclocking FAQ in bit-tech
http://forums.bit-tech.net/showindex.php?t=51323
4. Overclocking Guide in OC Forums
http://www.ocforums.com/showindex.php?t=263753
5. Link Guide for anyone new to Overclocking in PC Perspective
http://forums.pcper.com/showindex.php?t=173635
6. Overclocking Guide in Help Overclocking
http://www.helpoverclocking.com/english/index.htm
7. AMD Optimal BIOS settings + Overclocking Guide
http://www.madshrimps.be/?action=gethowto&howtoID=43
8. Tom's Hardware CPU Overclocking Forum (contains a few overclocking guides)
http://www.community.tomshardware.com/forum/postlist.m?Cat=&Board=over_cpu (for CPU)
9. Tom's Hardware Graphic Cards Overclocking Forum (contains a few overclocking guides)
http://www.community.tomshardware.com/forum/postlist.m?Cat=&Board=over_graphics (for Graphic Cards)
For a guide on Modding Tools, please read:
Modding Tools
Please post any comment and/or suggestion as well as dead link of this guide (Version 1.49) at the following thread:
Overclocking Guide Suggestion/Comment
I would like to thank for the help and support from Bas and Wonkanoby as well as advice from Raven_, Slimbooyphat and The Fellow in setting up this guide.
Wonkanoby
(No subject)
« Reply #1 on: 21-February-04, 14:19:14 »
  • Best Answer
  • http://www.neoseeker.com/Articles/Hardware/Guides/OCguide/
    this is a good read on the basics
    interesting pictures as well
    P5Q Deluxe
    Intel QX 6700
    4GB OCZ
    60 GB Vertex drive
    ATI 5850
    Jampy
    Thanks
    « Reply #2 on: 26-February-04, 03:39:31 »
    It's  a nice description!!!
     :biggthumbsup:
    AMD Athlon XP 2400+
    Msi KT6 Delta LSR
    TwinMos 512 DDR 400
    MSI FX 5600XT TD128
    Terratec Aeron 5.1 Sky
    Seagate Barracuda V 80 GB
    Texas Instruments FireWire controller
    Mercury 450W, I dont know the details exactly
    Win 2000 PRO with SP4
    mathew
    cooling
    « Reply #3 on: 29-February-04, 01:28:40 »
    :evil: this is a good place for  heat sinks and other cooling parts for overclocking http://www.2cooltek.com
    H2O Guru
    (No subject)
    « Reply #4 on: 12-March-04, 20:45:39 »
    Kingfisher, Good job, lots of great info on the basics of overclocking, very
    professionally done!
     The H2O Guru
    If You Build The Circuit The Electrons Will Come!
    _______________________________________ _____
    Enermax  550 v1.2 EG651P-VE PSU
    +3.3V=36A / +5V=36A / +12V=36A
    +5V & +3.3v = 200Watts
    nVidia MB Drivers v3.13
    nVidia VGA Drivers v53.03
    Wonkanoby
    (No subject)
    « Reply #5 on: 27-July-04, 07:59:13 »
  • Best Answer
  • http://www.deep-powder.net/OC_Guide/Mem_Mobo_CPU_Overclocking_Guide.htm
    this is a very good guide as well
    aimed at nforce 2 but covers a lot of things
    P5Q Deluxe
    Intel QX 6700
    4GB OCZ
    60 GB Vertex drive
    ATI 5850
    morfei1
    (No subject)
    « Reply #6 on: 12-August-04, 04:51:23 »
    Ray Adams ATI Tray Tool is another useful tool for ATI cards :biggthumbsup:
    timodeben
    (No subject)
    « Reply #7 on: 04-January-05, 04:26:54 »
    if you want to see a good site about cooling plz visit http://www.colorcase.be it is an belgian site but it has alot of english in it so everyone can enjoy
    Okay
    • CAPTAIN
    (No subject)
    « Reply #8 on: 16-January-05, 16:46:46 »
  • Best Answer
  • How about adding these modds:
    9800(pro) --> 9800XT (128MB)
    9600(pro) ---> 9600XT (128MB)
    9800SE mod (256bits req.)
    MSI NEO2 Platinum - Easy BIOS 1.C rev.2 (Thx Syar)
    AMD64 3000+ (Winchester)  @ 265 x 9 = 2385 MHz - 1.4 V - C&Q enabled
    Cooled by Artic Cooling Silencer 64 Ultra temp range: 33 - 48'C
    2 x 512 MB GeIL (Dual channel) - (150/200 div.)
    Sapphire 9600PRO Ultimate Edition - No fan => No Noise !!! :)
    200 GB WD SATA (8MB cache)
    Pioneer 107D DVD-RW (+ / -) Region Free ;-)
    Medion TV-tuner (only got one TV, and the misses dosen't like football)
    Artic Cooling T1 w/350W SeaSonic (all this on 17A@12V)
    Good news: A work-around to make VLC work with the nVidia sound drivers
    danny14871
    RE: Overclocking Guide
    « Reply #9 on: 04-February-05, 09:54:32 »
    The hidden functions in Nvidia card; How to create the file with notepad using regedit. Could you explain the exact procedures and e-mail to to danny14871@yahoo.com. Your Overclocking guide ROCKS!!! :biggthumbsup:
    ferohh
    Re: Overclocking Guide
    « Reply #10 on: 28-February-05, 14:39:20 »
    I tried to overclock my p4. 2,66ghz to 3.18ghz.
    l increased the cpu fsb only since the multiplier is fixed at 20x.
    l tried to change it but couldn´t.
    l then increased my cpu voltage from 1.525v to 1.732v.
    At 3.2ghz, the computer was on and restarts automatically, so l turned it to 3.18ghz.
    does it mean the cpu will not overclock further or l need a new cooler?
    I did not overclock anything except the fsb.
    any help?
    grandgnu
    « Reply #11 on: 13-September-05, 08:48:57 »
    any help?
    I have a 2.6C Northwood pentium 4 on an MSI 875P Neo2-FISR mobo.  On air I'm able to get it to about 3.14Ghz stable.  I don't believe it's a good idea to go past 1.6 for the voltage, from what I've read, voltage doesn't help too much with the northwoods.
    I can overclock mine higher without any significant changes in temperatures, but the overclocks aren't stable and the system freezes up from time to time.  I'm using Kingston HyperX PC4000 DDR, which can run at up to 500mhz, so I can do a 1:1 ratio on the overclock.  I'm using a modular 500-watt power supply, Arctic Silver 5 and a huge honking Swiftech heatsink with an 80mm fan.
    russellmrgn
    • CAPTAIN
    « Reply #12 on: 13-April-06, 08:35:16 »
  • Best Answer
  • Here is another "how to" hosted at Short Media entitled "Overclocking on the 754/939 Platform" dated Feb 08 2006
    Link:-   http://www.short-media.com/review.php?p=1&r=300
    :biggthumbsup: Proud to be Folding for Team MSI :biggthumbsup:
    PC Details :-
    Case: Antec P160
    Case Fan: Akasa Amber 120 x2
    M/Board: MSI K8N  Platinum SLI (MS-7100)
    BIOS: Award 3.9
    CPU: AMD 64 4400 Dual Core
    Heatsink: Thermalright Si-120 & Tt Silent Cat 120 Fan
    Memory:  2GB Corsair 3500LL Pro (2x 1GB)
    Graphics: AOpen Aeolus 7800 GTX x2
    H/Drive: WD 74GB Raptor x2 Raid 0
                WD 250GB x2 Raid 0 (16mb Cache sata-2)
    Sound: Creative X-Fi Extreme Music
    PSU: Seasonic S12 600w
    Drives: Pioneer 110 x2 & Sony Floppy
    Monitor: DELL 2405FPW
    OS: Win XP Pro SP2 / IE 6
    raisethe3
    • SECOND LIEUTENANT
    • THE MSI HEAD
    « Reply #13 on: 23-November-09, 17:02:03 »
  • Best Answer
  • I noticed no Orthos mentioned for stress testing.  Its a very good program in my opinion.
    MSI K9N2 SLI Platinum
    AMD 64 X2 5600+ @ 3.0Ghz O'CD
    Bios Version 3.5 (10/08/2009)
    2X 2 GB Corsair RAM 4-4-4-12  800 MHZ
    EVGA 8800GT 512MB DDR3
    16X DVD+/- RW Dual Layer
    Corsair 650TX Watts PSU
    Computers
    « Reply #14 on: 10-October-10, 20:54:21 »
  • Best Answer
  • I find information about overclock Intel Core I7 system with MSI X58 motherboar
    link: http://forumhardware.net/forum/index.php/board,7.0.html
    khaidir1976
    « Reply #15 on: 04-June-13, 04:43:46 »
  • Best Answer
  • Comprehensive guide!  :agrees:
    Kitarist
    « Reply #16 on: 02-October-13, 15:34:18 »
  • Best Answer
  • Really nice guide!!! :)
    Sea Dog
    • LIEUTENANT COLONEL
    • Aye! Cannons Be Loadin' Cap'n!
    « Reply #17 on: 03-January-14, 20:12:02 »
  • Best Answer
  • Even after almost 10 years since it was originated, it still has some value.  ;-))
    Recent Acquisitions: Z68A-GD80(G3), Z77A-GD80, X79A-GD65(8D) Played Around With A Z87-MPower Max, 4770k. At Last! A Z97 To Play With For Awhile!
    P67A-GD65(B3)/i7 2700k/Zalman 9900/GTX 680's SLI/Corsair 2X4GB 2133/WD 600 V.Raptor & 640 Caviar Black/iHAS424/Lian-Li 60BPlus II/Samsung T220/Corsair HX850/W7 Ultimate 64 SP1 (Mothballed)
    MSI X58 Pro-E/i7 950/Zalman 9900/ASUS 4870X2 Tri-Fan/Corsair 3X2GB PC3-12800/WD 300 V.Raptor/WD 640 Caviar Black/Lite-On iHAS422/Lian-Li 60BPlus II W/Samsung T220/Corsair TX850/W7 Ultimate 64 SP1
    MSI P45 Platinum/E8600 (EO)/Zalman 9900/ASUS 4870/Corsair 2X1GB PC2-8500 @ 1067/2X WD 150 Raptor X's/Lite-On LH-20A1L/Lian Li 60BPlus II/Samsung 906BW/Thermaltake TP 850W/XP SP3
    Gamma
    • SERGEANT
    « Reply #18 on: 08-April-14, 14:44:38 »
  • Best Answer
  • Good day Can any one Direct me in the right Direction for My MOBO and CPU OC Guide ??  to a New Guide
    Many thanks
    operating system! 764X ultimate 4.4 stable, testing 4.5
    Processor: Intel ® Core i7- 4770K processor
    Gigabyte GeForce GTX 760 OCWF3X,2GBDDR5
    Maximum memory : 32GB / on board 16gb DDR3 1600 Fan: Scythe Katana 3, PSU : Cougar Power 700 W
    Memory clock : 1600 MHz DDR3, CL10 9-9-9-24
    SSD : SAMSUNG SSD 840 PRO 128GB
    Motherboard: MSI Z87 -G45 GAMING ATX
    Case: Cougar Evolution 6GR1B black
    Software_Z3 : System Software Utilities
    HDD: WD Caviar Green 2TB SATA 6Gb / s
    Network: Gigabit Killer E2205,Chipset: Intel Z87 Express
    Jak1up
    • CORPORAL
    « Reply #19 on: 09-April-15, 16:28:18 »
  • Best Answer
  •  :)........4.5Ghz..........everyday clock................
    MSI Z87-GD65 Gaming/ Bios-.1B2/ MSI GTX770 2G Gaming/16g-Adata XPGx1 2133MHz / i7-4770k@4.5GHz/SanDisk 256GB SSD/Seagate 1T Hybrid Dive/ Windows 8.1/Cooler master Seidon240m/Thermaltake XT750w/Cooler Master HAF X.................
    • 微星科技
    « Reply #20 on: 10-April-15, 06:08:54 »
  • Best Answer
  • This dead old topic gets locked to prevent further resurrections.
    :floblock:
    AMD Ryzen 9 3900X
    Windows 10 Pro
