Author Topic: What is the Amp draw for Ti4400  (Read 1204 times)
FXMan
« on: 22-September-02, 06:05:50 »
I am trying to do AMD's System Power Worksheet to figure out if I need to upgrade my PSU when I build my new system.
I can't find anywhere what the power requirement is for the GeForce4 Ti 4400.  I know it is power hungry and draws off of the 3.3V line... but I don't know how many amps it draws.
Athlonix
(No subject)
« Reply #1 on: 23-September-02, 10:34:10 »
20Amps on 3.3v will run a 4600 :))  hope that helps, but i don't know its draw sorry :(
FXMan
(No subject)
« Reply #2 on: 29-September-02, 21:22:28 »
That is the exact thing I'm looking for.  20A is it's draw...
Where abouts did you find that info?  I haven't been able to find it anywhere.
Athlonix
(No subject)
« Reply #3 on: 29-September-02, 22:01:47 »
well just that i was using 20A @ 3.3v on a 4600 and it worked
