Author Topic: Msi Cd-rw Ms-8348  (Read 1080 times)
TONYHATTON
Msi Cd-rw Ms-8348
« on: 01-April-04, 05:55:23 »
I HAVE A MS-8348 AND IT WAS WORKING FINE. ALL OF A SUDDEN I STARTED GETTING "NO SEEK COMPLETE" ERRORS, SOMETIMES IT WOULD BURN A BIT OF THE CD, SOMETIMES MOST OF IT. IT IS FRUETRATING THE #$%& OUT OF ME.
I HAVE UPDATED THE FIRMWARE AND STILL NO DIFFERENCE. ANY IDEAS ???
noeldeg
« Reply #1 on: 01-April-04, 09:12:37 »
Try a dry CD-Cleaner... it may be that your laser lens got dirty.
TONYHATTON
« Reply #2 on: 01-April-04, 21:46:19 »
Cheers dude :-)) , I WILL GIVE THAT A GO .
Blazing
« Reply #3 on: 16-April-04, 01:19:17 »
Try lowering the burn speed on your burner (Either through the burning software or the properties in My Computer). I had the same exact problem and bumping the speed down to 24x (from 48x) seems to have done the trick.
