Author Topic: G3Ti200 Tv-in  (Read 1144 times)
rhonedog
G3Ti200 Tv-in
« on: 29-September-02, 01:59:53 »
When I try and capture footage from my video camera to my pc, I only get black and white images. The card outputs color to tv fine, but the input is always black and white. I am connecting through the SVHS on the back of the card. Has anyone else experienced this? And what did you to to fix it?
Thanks!
Mike R
crAzy_caMel
(No subject)
« Reply #1 on: 29-September-02, 12:25:02 »
The program you use should have an option for the Composite or S-video on the input device.
Try changing these around.
