Author Topic: Problems Ti4400  (Read 1726 times)
TheeD
Problems Ti4400
« on: 29-September-02, 13:45:50 »
Hi there,
a few weeks ago i bought a new system:
asus A7V333 MB
MSI Ti4400
WIN Xp prof.
The first week everything runs splendid, but after the first week the problems began. After a hour, out of nowhere, yellow lines and dots began to appear on my screen, in the normal prpgrams like windows en explorer. After a view lockups winXp gave a error report concenrning my videocard. So i update my drivers, with no result.......
It only got worse an nowadays the flikkering lines and dots appear istantly when i starup my pc.
Does anybody have the same probs ??? and what did you do about it ???
Ed
Wonkanoby
(No subject)
« Reply #1 on: 29-September-02, 14:11:46 »
  • Best Answer
  • got a descent 200 plus watt combined rated psu in itlink
    P5Q Deluxe
    Intel QX 6700
    4GB OCZ
    60 GB Vertex drive
    ATI 5850
    TheeD
    (No subject)
    « Reply #2 on: 29-September-02, 14:15:53 »
    yup, a 300 watt atx-12v cwt1035 LN, so i think i got enough juice
    Wonkanoby
    (No subject)
    « Reply #3 on: 29-September-02, 14:19:02 »
  • Best Answer
  • whats its quoted combined then
    as 300 watt means nothing,who makes it
    P5Q Deluxe
    Intel QX 6700
    4GB OCZ
    60 GB Vertex drive
    ATI 5850
    TheeD
    (No subject)
    « Reply #4 on: 29-September-02, 14:25:56 »
    nope can't find any more info than this:
    Power supply: 250W/300W ATX12V
    Wonkanoby
    (No subject)
    « Reply #5 on: 29-September-02, 14:26:45 »
  • Best Answer
  • amps 3.3 and 5 v
    P5Q Deluxe
    Intel QX 6700
    4GB OCZ
    60 GB Vertex drive
    ATI 5850
    Wonkanoby
    (No subject)
    « Reply #6 on: 29-September-02, 14:40:56 »
  • Best Answer
  • any psu should have a label on it quoting amps at those 2 voltages,better ones will state a combined for 3.3 and 5 v as well
    P5Q Deluxe
    Intel QX 6700
    4GB OCZ
    60 GB Vertex drive
    ATI 5850
    TheeD
    (No subject)
    « Reply #7 on: 29-September-02, 14:47:41 »
    nope can't find it................
    Wonkanoby
    (No subject)
    « Reply #8 on: 29-September-02, 14:51:10 »
  • Best Answer
  • read the thread i linked you to and get a descent branded psu antec 430 like they are using
    make sure label states combined is over 200 watts
    P5Q Deluxe
    Intel QX 6700
    4GB OCZ
    60 GB Vertex drive
    ATI 5850
    WarLord
    Ti4400
    « Reply #9 on: 29-September-02, 17:01:04 »
    Yes i hear you dude i have the same lines and dots as you do. Im running the KT3 Ultra Aru and its been going on for three months and i need answers!!!!! i had to take the card out completly and DOWNGRADE my system to the GF3 Ti 200 so whaaazzz up with this CRAP ??        My psu is a TTGI and the combined is 280w 3.3v 5v and i currently am running the Ti4400 in a 240w psu and it runs fine there that also is a MSI board the KT133 so i dont think that is the problem, i dunno
