Author Topic: Nvidia boot agent problem  (Read 1919 times)
jcomerma
« on: 23-October-04, 19:54:01 »
After building the PC, on the initial boot process everything looks fine until I reached the NVIDIA boot agent.
After it blanks the screen, it says:
"NVIDIA boot agent 201.0440
copyrights...
After 10 to 15seg its shows the following message:
PXE-E61: media test failure, check cable
PXE-M0F: exiting nvidia boot agent
It doesn't matter if I connect 1 or non HD, CD-ROM drive, or any combination: it’s always the same message.
If the CD-rom is connected, a "boot from CD:" message appears right before the Nvidia boot agent 201.0440 message. But the Boot Agent ends in the same way.
It seems to be a problem in the boot agent, not in connections (cables).
The hard disk is empty. I haven't been able to run the windows XP CD.
I tried with and old floppy (W98 emergency disk) but it's the same. It doesn’t seem to read the floppy, or the WXP CD.
I've cleared the CMOS. I've checked every cable I know. Don't know what else to check.
I don't see any information on Nvidia boot agent in the MSI webpage.
Any commend is welcome
Juan
dacull
  • CAPTAIN
« Reply #1 on: 23-October-04, 20:01:10 »
  • Best Answer
  • What have you got for your boot order, and boot priority ? two different settings in the bios, the boot priority is especially important and doesn't work how it should, ensure that your CD is at the top of the boot priority and is in the boot order.
    I think if you hit F11 on boot it comes up with a separate boot priority list, select CD from that and it should boot from CD and enable you to install XP to your HD..
    Just a guess.
    MSI K8N Neo2 Platinum 54G v1.8 (C&C Working)
    AMD Athlon64 3500+ (DH7 CG)
    Gainward Ultra2400 (Nvidia 6800 GT) @ 400/1150
    Iiyama Hm903DTA Pro 454 (100hz)
    2*512 Kingston KVR400X64C3A/512 CL 2.5 1T aggr Dimm 1 2 @235Mhz
    USB Intellimouse Explorer 4.0 optical mouse
    USB Generic Keyboard (PS2 keyboards don't work)
    Antec Trueblue Truepower 480W (+5V 38A/+12V 22A/+3.3V 30A)
    MSI DVD-burner DR8P IDE
    MSI Wifi card in Comm slot
    Samsung DVD-Rom SD616E
    Maxtor MaXLine Plus II 250GB S-ATA in last Sata slot 8MB cache 7200RPM
    Windows XP Pro SP2 / Linux 64bit AMD64 FC3 2.6.11
    Lian Li PCV1100
    pinochio
    « Reply #2 on: 23-October-04, 23:25:50 »
    The problem is the BIOS doesn't find your boot drive so it goes donwards in the order you set in the BIOS as a boot source.
    First check how that order is set and set 1 Boot Device as Hard Disk.
    If that doesn't do the trick start looking for reasons you HDD isn't working (like power plug,IDE or SATA cables e.t.c)
    Good luck  :biggthumbsup:
    William
    « Reply #3 on: 30-October-04, 13:51:01 »
    I had the same problem
    The hard drive May not have been fromatted
    Test it on a Win 98 Boot Floppy
    Get  it from http://www.bootdisk.com
    select WIN98 SE OEM
    I thought I had XP on my drive, but when I downloaded a WIN 98 Boot Disk, there was no Drive C: so it became the RAM drive.
    I booted from a Win XP professional CD, and it looks to be working.
    Formatting as NTFS 1 Partition
    Only problem is I wanted it to be a WIN 98 PC.
    Ah well....
    If I dont update this within 2 hours, you can assume that the NVIDIA Boot Agent means  the HDD is not formatted.
    The odd thing is I tried to format the drive with a Western Digital Floppy & it did not want to know. :bonk:
    jcomerma
    « Reply #4 on: 30-October-04, 14:08:11 »
    thanks all, My problem was a wrong order in the boot process, and a non-booteable windows XP copy. too many mistakes...
    thanks
