Author Topic: Flashing Under Linux?  (Read 1539 times)
elektronisch
« on: 31-October-04, 21:31:19 »
I was wondering there is a way to flash my motherboard in Linux.  I do not have a floppy drive, just a USB jump drive.  Is there a method that anyone knows about?
Thanks,
Jason
WienOnline
(No subject)
« Reply #1 on: 31-October-04, 22:41:47 »
Hi!
Flashing a BIOS under Linux is (until someone finds a solution) next to impossible since the kernel won't let you access the hardware directly.
You better get yourself a DOS Bootdisk from http://www.bootdisk.com/ and write it onto a floppy. If you have access to a Windows XP based system simply insert a diskette, open "My Computer", right click "3.5" Floppy", select "Format" and choose "Create system disk". This will give you a bootable floppy as well.
As soon as you have a bootable floppy download the appropriate BIOS for your mainboard and extract the contents onto the floppy. If there's not enough space clean up the floppy until there are only command.com, io.sys, msdos.sys left on it. Since you are running Linux be sure to mount it FAT12 and not FAT16 or, even worse, FAT32.
Shutdown, insert the floppy into the disk drive and let your system boot.
On the command prompt you might want to type:
A:\> amiflh A6702VMS.180 /a
NOTE: The example above refers to an K8T Neo!
Hope this helps.
elektronisch
(No subject)
« Reply #2 on: 03-November-04, 23:22:35 »
I only have a USB stick drive.. no floppy.
aarrgghh!
(No subject)
« Reply #3 on: 03-November-04, 23:28:53 »
LOL, jeez, do you have a Imac? Honeslty, unless one of the other wise sages here knows of another way, the only way your going to flash your machine is with a floppy drive and some boot disks, or a cd drive and a boot cd. I personally have never flasjed a BIOS with a bootable cd, so I would ask the gurus here for advice on that.
elektronisch
(No subject)
« Reply #4 on: 04-November-04, 19:37:11 »
bump :(
elektronisch
(No subject)
« Reply #5 on: 07-November-04, 02:16:24 »
osnavi
  • GENERAL
(No subject)
« Reply #6 on: 07-November-04, 06:39:02 »
  • Best Answer
  • Well, it's not much money involved in buying (less in borrowing) a FDD. so....
    MSI KT3 Ultra 2 ARU
    Athlon XP 2800+Thermaltake Heatsink fan
    2x 512 Mb DDR PC 2700 Spect
    MSI FX 5900XT 128 Mb
    SBlaster Audigy Platinum
    HDD 0 Maxtor80Gb HDD1 Maxtor120Gb both Ata 133-7200 RPM
    USB 2.0 HDD 80 Gb.
    MSI CDR 52x
    Aopen CDRW 48x12x50x
    Pinnacle DV500 VidEditor
    Thermaltake 420W 3.3v.-30A 5v.-40 A 12v-18A
    USB 1.1 Memory Stick Card Reader
    Floppy Drive
    PS2 & USBMouse
    WXP SP1
    Fredrik
    • There's always a risk.
    RE: Flashing Under Linux?
    « Reply #7 on: 07-November-04, 10:45:25 »
  • Best Answer
  • Linux is Greek to me, but I found this:
    http://colt.projectgamma.com/bios/flashing.html
