Author Topic: Error Message, Please Help  (Read 2311 times)
angelchild42
« on: 20-January-05, 04:00:08 »
I'm getting the following message:
"A problem has been detected and windows has been shut down to prevent damage to your computer.
If this is the first time you've seen this Stop error screen, restart your computer. If this screen appears again, follow these steps:
Run a system diagnostic utility supplied by your hardware manufacturer. In particular, run a memory check, and check for faulty or mismatched memory. Try changing video adapters.
Disable or remove any newly installed hardware and drivers. Disable or remove any newly installed software. If you need to use safe mode to remove or disable components, restart your computer. press F8 to select Advanced Startup Options, and then select safe mode.
Technical information:
*** STOP: 0x0000007F (0x00000000, 0x00000000, 0x0000000, 0x0000000)"
I just got this Motherboard and cpu, and I am trying to boot from the win XP cd to install it.  It starts to install then this message pops up.  I'm pretty darn sure I've plugged everything in correctly, and I am wondering if there is something in BIOS that I need to do.
PLEASE HELP!
angelchild42
« Reply #1 on: 20-January-05, 04:20:15 »
I will be getting new memory but This is it so far
K8N Neo Plat 2
AMD 64 3500 (939)
Sapphire Tech ATI Radeon 9800 Pro
2, 512 Kingston 266 2700
WD 80 G 8mb Cache 7200 RPM (master, has XP on it from last Motherboard)
Samsung 20 G 2 mb Cache 5400 RPM
WD 74 G Raptor 8mb Cache 10000 RPM SATA (not being Identified)
FastEddie
« Reply #2 on: 20-January-05, 04:23:39 »
Go into the cmos setup and set your boot order to cdrom, harddisk,floppy, then try booting to the WinXP cd in the drive.
RollerCam540
  • FIRST LIEUTENANT
« Reply #3 on: 20-January-05, 04:49:35 »
  • Best Answer
  • FastEddie is right. It sounds like your old version of Windows XP is loading the old drivers on your new hardware and obviously it's not working; thus, you get a Blue Screen Of Death (BSOD).
    Try doing what FastEddie said. Repair or re-install windows and see what happens.
    The guys here at the forum recommend a fresh clean install of windows when doing anything.
    AMD Athlon64 90nm 3200+ (2000mhz) @ 2750mhz
    MSI K8N Neo2 Platinum @ 275mhz FSB (1:1 ratio 275x10)
    1GB (2x512mb) of G.SKILL DDR550 PC4400 ram (2.65v)
    Enernex 550w PSU
    +3.3v/36A +5v/36A +12v/36A -5v/1A -12v/1A +5VSB/2.2A
    2xMaxtor 80GB 6Y080M0 SATA150 Hard Drive
    MSI 6600GT 8xAGP 128MB DDR3 Video Card
    Windows XP SP2
    angelchild42
    « Reply #4 on: 20-January-05, 05:31:17 »
    Guess I should have mentioned this before, but I Boot from CD and it starts installing win xp, then when it says windows is starting setup, thats when it happens, I can't even start reformatting. I'm going to try to boot with a win 98 disk so that I can delete the active partitions,  and start from scratch.
    FastEddie
    « Reply #5 on: 20-January-05, 05:33:47 »
    You can delete the active partitions with the WinXP cd as well.  Wait for the prompt "Press any key to boot to cd" then boot to the WinXP install cd.  Delete the active boot partition there, create a new boot partition, format the partition, install the os, etc...
    angelchild42
    « Reply #6 on: 20-January-05, 05:36:35 »
    Nevermind I was dumb :-P
    angelchild42
    « Reply #7 on: 20-January-05, 05:51:57 »
    YAY I'M SETTING UP RIGHT NOW.....will post if I have any more developments.
    RollerCam540
    • FIRST LIEUTENANT
    « Reply #8 on: 20-January-05, 06:43:47 »
  • Best Answer
  • what did you do to fix it? we need to know this so we can help other people with your problem.
    Enernex 550w PSU
    Windows XP SP2
    killprix
    « Reply #9 on: 29-January-05, 20:36:54 »
    Im having the same problem... what did you do to fix it?
    tckrto
    « Reply #10 on: 23-February-05, 11:28:17 »
    Mi oso having same problem. My friend oso having same problem but different mobo. he using Gigabyte nforce3 mobo. But wat i think the cause of problem is the ati graphic card driver conflict with the nforce gart driver. It seems to have a order of installation. I m still working on it. will post once i resolve the issue. =)
    • T9246ED, Бивша комета
    • Administrator
    • Online Online
    « Reply #11 on: 23-February-05, 12:12:59 »
  • Best Answer
  • possible reason for error:
    Stop 0x0000007F or UNEXPECTED_KERNEL_MODE_TRAP
    The Stop 0x7F message indicates that one of three types of problems occurred in kernel-mode:
    Resolving the Problem:
    A condition that the kernel is not allowed to have or intercept (also known as a bound trap).
    Software problems.
    Hardware failures.
    Stop 0x7F messages are typically due to defective, malfunctioning, or failed memory hardware. If you added new hardware recently, remove and replace it to determine if it is causing or contributing to the problem. Run diagnostics software supplied by the system manufacturer to determine if the component has failed.
    Running the CPU beyond the rated specification, known as "overclocking," can cause Stop 0x7F or other error messages due to heat buildup. When diagnosing problems on overclocked systems, first restore all clock and bus speed settings to the manufacturer recommended values to determine if this resolves the issues.
    The problem might also be due to cracks, scratched traces, or defective components on the motherboard. If all else fails, take the system motherboard to a repair facility for diagnostic testing.
    Stop 0x7F messages can occur after installing incompatible applications, drivers, or system services. Contact the software manufacturer about possible Windows XP Professional-specific updates. Using updated software is especially important for backup programs, multimedia applications, antivirus scanners, and CD mastering tools.
    Other reason:
    SYMPTOMS
    Your Windows 2000-based computer or Windows XP-based computer that is running Terminal Services may stop responding, and then you receive the following error message on a blue screen:
    0x0000007f (0x00000008) error STOP 0x7f
    The Win32k.sys file is listed as the source of the Stop error.
    When you shut down and restart your computer, the computer starts normally. However, the Stop error recurs regularly.
    Other reason:
    Error Message: "STOP 0x0000007F" During Setup on HP Pavilion 7840
    When you try to install or upgrade to Microsoft Windows XP Professional or Microsoft Windows XP Home Edition on a Hewlett Packard Pavilion 7840 computer, you may notice the following behavior. The first time that you restart the computer, you may receive the following error message: STOP 0x0000007F (UNEXPECTED_KERNEL_MODE_TRAP)
    Computer Turns Off During Text-Mode Setup If it Is Too Hot
    When performing a clean installation of Windows XP, you may experience one of the following symptoms during the text-mode portion of Setup: You may receive a "STOP 0x0000007F" error message. The Welcome screen may appear, and your computer may then turn off.
    0x0000007F or UNEXPECTED_KERNEL_MODE_TRAP (TechNet article)
    The Stop 0x7F message indicates that one of three types of problems occurred in kernel-mode: A condition that the kernel is not allowed to have or intercept (also known as a bound trap); Software problems; Hardware failures.
