Author Topic: Mega PC Original Bluebird Firmwares for 180 and 651  (Read 5248 times)
StuTopic starter
  • Birmingham, UK
    • StuOnline.co.uk
« on: 22-February-05, 18:28:49 »
In case of problems with updating firmware for the Bluebird / LCD modules on the Mega 651 and 180, you can find the original factory firmwares here
Please only use these if you need to. If a serious error has occured, there is no guarantee that this will fix it.
MEGA 180 -     Download "MEGA 180 Firmware 0C.zip"
In order to flash this firmware into your units please follow the following procedure -
1.Boot to pure DOS (using a bootable CD which can be made in Nero e.t.c)
2.Type "i2cdown -b:3 -d:0xd0 -a:0xa4 -target:rom XXXXX.bin" - Then press enter.  (Where XXXXX.bin is your updated firmware file)
3. Flash
4. Pull out the power plug. Restart.
MEGA 651     - Download "BlueBirdV63.zip"
the procedure remains the same as before: you'll need either a bootable floppy, USB stick or CD.
extract the ZIP to the floppy, usb stick or CD and boot into DOS. run the flash.bat program. when completed, you MUST power off your mega 651 and UNPLUG the power cord from the unit for a few seconds, then reconnect and power back on.
if you need more information see these topics:
Mega 180: https://forum-en.msi.com/index.php?topic=46355.0
Mega 651: https://forum-en.msi.com/index.php?topic=73906.0
[ IMAGE NOT SHOWN - GUESTS CANNOT VIEW ATTACHED IMAGES ]
lemel
  • STAFF SERGEANT
    • MSI UK
Re: Mega PC Bluebird Firmware for 180 and 651
« Reply #1 on: 23-February-05, 05:19:14 »
How about Mega 865?  Is this different Firmware?
Do you have that also?
Trying to do the best with what little i have...
Follow me on twitter /richardastewart
Follow msi on twitter /msitweets
StuTopic starter
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #2 on: 23-February-05, 12:13:17 »
no-one has ever needed it! i'm making a big guess to say that it is  p r o b a b l y  the same as the mega 180, as they basically use the same front panel LCD display, but please don't take my word for it
ajcmail1
« Reply #3 on: 11-April-05, 23:08:08 »
Hi, I have a MEGA 865 with a dead LCD.   In the past I was able to get it to work again by unplugging both the power cord AND the LCD connector overnight.   It would then work for a few days.
This past weekend I updated the LCD firmware using the I2CDOWN procedure for the MEGA 181.   Now it does not work at all.  I guess the 181 firmware is not compatible with the 865.
Can anyone tell me how to get the firmware for the 865?   Or how to contact MSI Support?  I can't find their tech support contact information.  The web site says to contact the reseller and I'm sure they are not going to know what to do.
Thanks for any info.
Wonkanoby
P5Q Deluxe
Intel QX 6700
4GB OCZ
60 GB Vertex drive
ATI 5850
StuTopic starter
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #5 on: 12-April-05, 12:06:46 »
if you do receive a firmware file then help others! send it to me or wonka, and we can post it here with the others
caesar_s
Re: Mega PC Original Bluebird Firmwares for 180 and 651
« Reply #6 on: 05-October-05, 09:36:30 »
Worked beautifully for me too. Am a very proud owner of a fully functional Mega 180. I'm using mine as a Media PC.
BTW does anyone know of a good remote for the MEGA 180 that can also control a mouse?
~Caesar
fredlamour
« Reply #7 on: 10-February-08, 13:20:48 »
hi,
could you please send me the MEGA 180 LCD firmware available at <removed by moderator> ?
File is not available for download on the mentionned post.
Regards
Mega PC 180
Semprom 2600+ - 1024 Mo DDR
HDD 160 Go and TV Card Asus 7132
-- Windows XP SP2 --
StuTopic starter
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #8 on: 10-February-08, 15:59:15 »
hi,
Regards
I just tried and it worked for me, its attached to the first post in this topic
Or click here >>> https://forum-en.msi.com/index.php?action=dlattach;topic=74625.0;attach=393
