Author Topic: Bios Flash - PT880 Neo N1996 MS - 7008 Ver: 1  (Read 3855 times)
pypesco
« on: 03-April-05, 22:19:49 »
I ran a driver update from the MSI Live Monitor (TSR) on my computer.  I created the Bios update floppy and rebooted.  In the DOS mode, I am about to run the flash program but I am reminded to "Please disable the item 'Bios Protection' in Bios set-up".  I reviewed my quick user's guide (Bios section) and couldn't find an item BIOS PROTECTION listed.
Can I safely conclude that bios protection (run/disable) is not a function in my particular bios set-up and that it's SAFE to run the flash program?
Thanks so much!
SBP
Arizona
Del UK
  • Del UK
  • MAJOR GENERAL
    • http://www.msi.com.tw/
« Reply #1 on: 03-April-05, 22:26:24 »
  • Best Answer
  • Hi,
    Just to be sure..........
    a floppy disk with a bios for your mainboard (MSI retail NOT MSI oem)
    You need to have floppy in drive and press **** key (marked OUT) to restore to safe working bios
    Del X-((
    Main system
    MSI P45 FR3 V1, Q9550 with Corsair H50, Corsair TX 650, Nvidia 650 ti boost, 8Gb DDR2 Corsair XMS2, onboard NIC/Audio, WD 250 with Synapse  & 500 RE drives, Opti Bluray, Enermax batwing 120's. Win 7 Pro 64bit
    pypesco
    « Reply #2 on: 03-April-05, 22:34:32 »
    On page 3-10 there is a reference to "BIOS password protection".  Is this the 'Bios protection' that is being refered to in the preflash warning, "PLEASE DISABLE THE BIOS PROTECTION IN BIOS SETUP" ???
    Thank anyone!
    Del UK
    • Del UK
    • MAJOR GENERAL
    « Reply #3 on: 03-April-05, 22:45:31 »
  • Best Answer
  • Hi,
    BIOS restore from FLOPPY will over write ALL (http://www.msi.com.tw/program/support/bios/bos/spt_bos_list.php?kind=1)
    Bios update via FLOPPY will need protection disabled
    Del X-((
    Main system
    pypesco
    « Reply #4 on: 03-April-05, 22:57:29 »
    so bios protection refers to bios password protection?
    Del UK
    • Del UK
    • MAJOR GENERAL
    « Reply #5 on: 04-April-05, 21:55:35 »
  • Best Answer
  • No bios protection is to prevent bios being overwritten or attacked.
    Main system
