Author Topic: Software & Driver problem with MS8826  (Read 3729 times)
gkjones
« on: 08-July-02, 17:05:16 »
I have an MS8826 (Geforce 2 MX400) installed in my machine (Motherboard K7S5a, Processor 1GHz Athlon, 256 Mb DDR ram)
I have installed the latest Nvidia drivers (29.) All works OK except DVD playback (using WinDVD) which frezes after a couple of seconds.
I am not using MSI DVD as I don't have the original drivers & software.
Can anyone tell me a way around this problem? I could install eariler drivers, but none of the eariler drivers kept the color correction i has set-up after a restart.
Also can anyone tell me where I can get a copy of MSI DVD and 3D Turbo that work with this card. I cna't get an answer from MSI support!
Thanks for the help,
Keith.
Richard
  • nForce & GeForce Guru
(No subject)
« Reply #1 on: 11-July-02, 00:56:24 »
  • Best Answer
  • Keith,
    Which OS you are running.  There are versions of WinDVD that do not work with WinXP.
    Also do you have an antivirus program running?   That can cause the freezing of frames over the playback of a movie.
    Take Care,
    Richard
    Richard J. Gentil, Pres.
    Custom Computers of Naples, Inc.
    LANPARTY nF4 SLI-DR
    Athlon64 3700+ Sandy
    (o/c'd 2.8Ghz)
    Zalman CNPS9500LED
    2-1Gb Mushkin Extreme PC-4000 (Slots 2 & 4)
    (o/c'd 510Mhz)
    2 x MSI NX6800GT-T2D256 (o/c'd Stock)
    X-Mystique 7.1 GOLD - Dolby Digital Live
    2-WD Raptors Raid 0
    (16k Stripe)
    NEC 16 Dual Layer DVD+/-RW
    Logitech Z-680 500W Dolby Digital DTS THX 5.1
    Logitech MX1000 Laser Mouse
    Saitek Eclipse Keyboard
