Author Topic: beep beep beep on boot  (Read 1440 times)
armageddon21
« on: 05-May-05, 23:54:37 »
I have a kt4v-l mother board,  recently my power supply died .. I bought a new one. but when I push power I hear a beep each .5 seconds
beep, beep ,beep beep, beep, beep etc.
I triesd to find the sound code for this boar don the net.. (wihtout success)
If someone could point me to a place where it says the sound codes  ( beeo on error)  It would be realy appreciated.
Thanks
Stephane
Grayone
  • LIEUTENANT GENERAL
« Reply #1 on: 06-May-05, 04:18:00 »
  • Best Answer
  • Hi,
    Here is a link to a beep code site.      http://bioscentral.com/beepcodes/amibeep.htm
    DKA790GX Platinum w/Phenom II 960T unlocked to 6 cores
    4 gig GSkill DDR2 800 @5-5-5-15-2T
    N460GTX & N450GTS
    Corsair 650TX  12v-52 amps
    Windows XP-SP3
    G31-M7 w/Q9400 @3.28GHz @1.312v
    2Gb DDR2 800 @5-6-6-15-2T
    GTX460 Hawk video card
    Seasonic 520 Watt S-12 12v-40amps
    Windows XP-SP3 - Folding 24/7
    armageddon21
    « Reply #2 on: 07-May-05, 18:15:10 »
    Mines is doing beep beep fast and never stops beeping,  does that mean anything? I didnt find that in the list.
    Thanks
    Grayone
    « Reply #3 on: 07-May-05, 18:18:41 »
  • Best Answer
  • If your bios is an award bios, endless beeps indicate memory problems.  Check the name on the bios chip.  Also you might try other memory in your system to verify.
    N460GTX & N450GTS
    Windows XP-SP3
    Wonkanoby
    « Reply #4 on: 07-May-05, 23:53:45 »
  • Best Answer
  • plugged the cooler fan in ?
    and the 4 pin 12v feed
    P5Q Deluxe
    Intel QX 6700
    4GB OCZ
    60 GB Vertex drive
    ATI 5850
    armageddon21
    « Reply #5 on: 12-May-05, 17:04:22 »
    MEmory is fine. I removed it and using it in another machine .
    Power is new and plugged of course..
    Maybe the Ram slot .  But I think its the board it self.  :(
    Grayone
    « Reply #6 on: 12-May-05, 17:11:18 »
  • Best Answer
  • Has it worked since you replaced the psu?
    N460GTX & N450GTS
    Windows XP-SP3
